Take a look at the back of the laptop. Is the gold power pin still there or is it now stuck in in the end of the power brick cord?
HP actually extended the wty on these machines because of the
power pin issues. If the power pin is missing you will need to have the machine serviced. Out of wty, replacement power pins are easy to solder on the board if this is the issue.
If your pin is still there... Your AC cord or power brick may be the next things to check. Connecting them to a meter will tell you if there is power. Try moving the cords to check for shorts in the wires.
If your AC cord and brick are good, try pulling the battery. Your laptop can run off AC only. Batteries with bad cells can sometimes prevent the machine from powering up.
If its still not powering up after all of that, there may be an issue with the motherboard in the machine.
I’m happy to help further over the phone at
https://www.6ya.com/expert/chris_084d18e3e5b62c52
