Question about HP ProCurve M111 (J9389A) 802.11a/b/g Wireless Bridge
The HP M111 working perfect until It looses power. After the power loose the unit falls off the network and needs to be reset to fatory defaults
Posted by kjbiehl on
dan
    Scholar:
  • 136 Answers
If you are using a ppoe connection then save your isp account user name/password in the modem weather it be a cable modem or a dsl modem and then setup and configure your access point device and SAVE your settings in the device.
if you using a dhcp connection from isp modems then just connect your access point device and setup amd configure your settings and SAVE them as well.
the only thing that i can think of is that you are not saving your settings and configurations. then when you you loose power the device reverts back to the default settings. also note that if there is some kind of "auto-configuartion" in the access point you may want to change that to manual configuration and create a new user name/password for your access point as well. please you MUST be hardwired connection when setting up the access point for the first time. please refer to the user guide for your access point for more detailed help on settings and configurations and how to save them in your device.
Posted on Aug 25, 2011
How do I reset my forgotten password
Plug into computer and enter IP address on label into web address bar or hold reset button for 10-20 sec to reset to factory settings.
Sep 09, 2014 | D-Link Computers & Internet
I want to reset my fatory setting for my lap top hp compac
HP Recovery Manager can be accessd by tapping F11 key as soon as you power on the laptop. Recovery Manager is used to reinstall back to factory specs.
Dec 12, 2013 | Computers & Internet
How do I data fatory reset an hp compaq nx9600
Try pressing [F11] repeatedly on Start-up, to access the Factory Recovery Partition.....
However, PLEASE note that you will NOT find Windows 7 drivers for your laptop if it is that old. (confirmed, HP only supports XP on that model.)
IOW....*IF* you could manage to get win7 to install on it, it is HIGHLY likely that parts of it would not work....video, network, cardbus slot, audio.....all of these would need windows 7 drivers to work properly.
you would likely be able to see a monitor image, but not be able to change the resolution much (stuck at 800x600) and the others....would be hit and miss. and if your network adapters (LAN and WLAN) did not work, I'm not sure of what use it would be to you.....
This is one of the pit-falls in Laptop/Notebook ownership. Although some models have lasted through more than one OS, they are a tiny minority.
Sep 04, 2012 | HP Compaq nx9600 Notebook
I need to reset default definition for this Printer. regards
If you are looking to factory reset, then what you need to do is turn the power off, turn the power back on, when the memory count starts, press and hold the 6 key until the three leds on the control panel stay on solid. Press the 3 key until "cold reset" shows in the display and then press 6 again. Unit will start up and factory defaults will be loaded. In some cases this will not clear the set network settings for the printer but it does get all other settings to factory.
Apr 13, 2011 | HP LaserJet M5035 MFP Printer
I erased my password how can i retrieve it
All you have to do is to reset the router.
Here are the steps and instruction to restore it.
Follow the instructions.
  1. Connect your computer to the router using an Ethernet cable.
  2. Step 2 Access the router by typing "http://192.168.1.1/" into your browser window. Use "admin" as the username and "password" or "1234" as the password. These are the default user name and passwords routers ship with. If you can access the router, change the wireless networkmag-glass_10x10.gif key. If the username and password do not work, proceed to Step 3.
  3. Step 3 Locate the reset button on the back of the browser and use an unfolded paper clip to press the reset button. Hold down the button for about 10 seconds until the test light blinks.
  4. Step 4 Wait for the router to reboot--about one or two minutes. Connect to the router as instructed in Step 2. After a reset, you will have to reconfigure all router settings, but you can also change the wireless network key.
Hope this might help you.
If i am helpful please rate me.
Thank you.
Yboyandrei
Aug 22, 2009 | Linksys Wireless-G Broadband Router
Hello, help please !!! In my companie there is more Compaq EVO T20 with loosed password ... how we can do to restore initial settings or delete it ? Thanks a lot in advance. Regards
Easiest way is to reflash it back to factory default somtimes pressing and holding G key when you power up will also return most setting to default once reflashed it is the Original Password set by HP/ Compaq if you do not know that perhaps you should not be playing with these units
Apr 21, 2009 | Compaq Evo T20 - 128mb Flash (305253001)...
Looses power when gets warm
then you need to check your timing
Nov 11, 2008 | 1989 Ford Bronco
Forgot username n password
you will need to reset the unit by depressing the reset button with a pen on the back of the unit.
Jan 26, 2008 | D-Link 802.11g Wireless Router WBR-1310...
HP 1610 all in one printer lost power
I'm assuming you've made sure the power cord didn't fall out. It could be possible that the ribbon cable to the head assembly is damaged or pulled loose. This would explain the first message of the "right cartridge needs adjusting". Check both ends to see if it's come loose and check the whole ribbon for damage. Also, do a full reset of all cables. (power, usb etc.)
Nov 25, 2007 | HP PSC 1610 All-In-One InkJet Printer
HP ProCurve M111 (J9389A) 802.11a/b/g Wireless Bridge Logo
165 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Toby Lee
Toby Lee
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
