Question about Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator
My first thought is that the control board has gone bad...that is why you cannot reset anything and turn the alarm off. So with that bad you basically can do nothing with it...diagnostics will not work either..
Unfortunately, unless you purchased an extended warranty, you probably have no coverage under warranty either.
New control boards should be available from searspartsdirect.com I tried to look up your part, but the model number you gave I think has one too many numbers in the second part. You have seven numbers and I think it should only have six...check the number and search for your model, then look for the control board.
A Tech. should be able to tell you for sure the problem in a few minutes, also, if you choose to go that route...
I will also say that an appliance just sitting can be very ******* them...moisture can get into them and with no internal air movement or heat it causes many problems, so because it has sat for so long it have have developed problems quicker then if you had used it the whole time...
Comment back if you have more questions...
heatman101
Posted on Aug 25, 2011
