Question about Maxtor 8E036JO 36G 80PINS SCSI 15K RPM HDD Hard Drive
Trying to find the jumper settings for a Seagate 36G 80PINS SCSI 15K RPM HDD Hard Drive with an apparent part number 8E036JO (all my Google searches say it's a Maxtor), but the one I have is Seagate. The Maxtor one's don't have jumper settings. Thanks Rod
Posted by rodnbrice on
Chris Hingee
  • 32,281 Answers
SCSI hard drives and devices have a jumper setting to configure the SCSI ID.
Each SCSI device must have a different ID.
The jumper/s are set for the following positions across 3 pairs of pins
: : : = SCSI ID = 0 no jumpers - usually for the boot hard drive
: : I = SCSI ID = 1
: I : = SCSI ID = 2
: I I = SCSI ID = 3
I : : = SCSI ID = 4
I : I = SCSI ID = 5
I I : = SCSI ID = 6
I I I = SCSI ID = 7
This gives a total of 8 possible SCSI devices on one SCSI controller.
Posted on Aug 25, 2011
Driver windows xp
browse over to http://www.seagate.com/internal-hard-drives/enterprise-hard-drives/hdd/cheetah-15k/ and select the options on the right hand side that match your drive. That will give you the model number.
Then go to https://apps1.seagate.com/downloads/request.html and fill in the model and serial numbers to get the right software drivers.
Jan 08, 2014 | Seagate Cheetah (ST3146807LW) 146 GB SCSI...
Trying to make my seagate barracuda 7200.9 slave
1) Open your computer case
2) On the back of the drive where the connectors are, you have jumpers. These small plastic tabs change the function of your hard drive. All hard drives have a special setup procedure. The information about jumper settings is on the top of the hard drive.
3) Remove plastic tabs and put them according to "Slave" instructions.
4) Connect drive to middle connector of the cord.
5) Connect power supply cord.
6) Secure the drive in place and close computer case.
Also make sure that the main drive is not set as slave.
Apr 10, 2011 | Seagate Barracuda 7200.9 80 GB Hard Drive
I could not set the jumper ID as 3 in Seagate 73 GB model of Hard drive.It has 12 pins at the back of Hard drive.
You need a jumper on ID pin sets 1 and 2 (as if you were setting it for both ID 1 and ID 2)
These pin sets work like binary, so set 1 for ID1, set 2 for ID 2, and sets 1 & 2 for ID 3. In this mannar, with just the 4 sets of pins, you can have IDs from 0 to 15 (no jumpers to all 4 jumpered..1+2+4+8=15)
1234 set number
1248 binary ID (additive)
If you need further explanation, please post a reply here.
Feb 24, 2011 | Seagate Hard Drive SCSI 73GB 10000RPM...
I have a 250gb seagate sata but when i put my 80gb IDE hdd it only detects in booting and in bios but after that if i open my computer i cant see my 80gb IDE Hdd and even in device manager my hard disk was...
there was wrong in the set up of jumper in your 80gb hdd. Look closely to the 80gb harddrive, in between the ide cable terminal and the power supply connector you will see 8pin terminals paired together and a jumper use to short the paired terminals. It is most likely that the jumper was configure to detect your hdd as master. If the ide cable you use for the 80gb hdd was also use for the dvd/cdrom drive then it will conflict with it if both jumper setting was set to master. See the description of jumper settings in the sticker of the hdd. Position the jumper to slave.
Reboot your system again and see if the 80gb finally appear in your system. When system boot upon detection of hdd, the primary master should be 250gb while your primary/secondary slave will be read your 80gb hard disk.
Jan 24, 2011 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
I have a r710dell server. It has two 146GB 15K RPM Serial-Attach SCSI 3Gbps 3.5in Hotplug Hard Drives. It seems like only one is being read. Because the C:\ is only 136GB. What could be the issue?
The two drives could be "mirrored" -- everything written onto one drive is also identically written onto the other drive. Thus, if one of the "set" of mirrored drives failed, you just remove the "dead" drive, insert a new drive, and tell it to "rebuild" the "set" of mirrored drives, i.e., it copies everything from the "good" drive onto the "new" drive, and then the "mirroring" will continue.
Dec 17, 2010 | Dell 300GB 15K RPM SAS 3.5-HPLUG HD R710...
How can i put a sas hdd in my laptop?any coverter scsi avaible?
if your laptop has a sas drive in there already yes as the interface is the same if not forget it. There is no physical adapter for it.use it externally in a case.
Sep 10, 2009 | Seagate 36GB Savvio 15K SAS 2.5" SCSI Hard...
How to slave the new SCSI HDD
Hello Fred...SCSI's are not all the same...
Is the SCSI controller built in to your motherboard or an add-in SCSI card? SCSI HDD's have selector switches on the back with numbers instead of master/slave jumpers...
Your motherboard BIOS might have an option...etc.
Go to your HDD's Mfrs. website...they will normaly have an overlay of the drive and it's applications.
Hope this helps...good luck.
May 23, 2009 | Seagate (ST3300655LW) 300 GB SCSI Ultra320...
HDD detection
What O/S are you installing? You might need to load the driver during the O/S install. Default ID for a scsi boot disk is 0. Make sure the scsi id is set to that id.
Apr 13, 2009 | Computers & Internet
Open Questions:
See all Maxtor 8E036JO 36G 80PINS SCSI 15K RPM HDD Hard Questions
Computers & Internet Logo
284 people viewed this question
Top Maxtor Computers & Internet Experts
ChinthakaJ
ChinthakaJ
Lucky
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
