Question about Microsoft Office Professional 2007 Full Version for PC
I HAVE A PRODUCT KEY AND WANT TO DOWNLOAD IT TO THIS COMPUTER BUT THE DISC ISN'T WORKING
Posted by candygirl566 on
Paljeet Singh
    New Friend:
  • 29 Answers
First download the Office full version on your hard drive.
Then what you need to do is burn the CD after it downloads.
When the CD completes and ejects. Press on the eject button to let it go in
so it loads the CD. After it loads then set it up.
If the CD doesn't work after burning then it's time to replace the drive.
I hope this works well for you.
Posted on Aug 25, 2011
Danilo Marcelo Jr
    Novelist:
  • 182 Answers
You need to do a lot of test, 1. check in bios if your cd-drive or dvd- drive is in enable if not enable it. 2. if your cd drive was enable, try to insert another cd, if the cd you insert was read by cd- drive, the problem is your cd. then if the other cd you insert is also din't work the problem is the cd-drive or dvd- drive. :P
Reinstalled Windows 7 but no product key
if you can get the old hard drive to work on your old computer for a short time
http://download.cnet.com/%7Bvalue=http://www.download.com/keyfinder-thing/3000-2094_4-10491989.html
Finding lost application install keys is quick and simple with this handy executable, a complete rewrite of a well-received earlier version. Keyfinder Thing's simple, easy-to-understand interface has Wizard-like efficiency. This application quickly scans your system registry for 90 supported software titles and displays product names and icons in the result window. Single-button clicks copy all keys to either a text or HTML file.
http://download.cnet.com/product-key-finder/3000-2094_4-10694022.html Product Key Finder is a single function utility that executes in a GUI, but displays a Command window result. You merely double-click it to display the 25 character Microsoft Windows Product Key.
then store it away for safe keeping not on your computer
hope this helps
Sep 30, 2012 | Computers & Internet
Product key for pavilion dv6
If it isn't working, call HP tollfree... they will be able to tell you. If it's the product key for the WINDOWS Operating System software or OFFICE SUITE there is another answer. The computer must be working. START>RUN>type REGEDIT and then follow Microsoft's instructions
fhttp://support.microsoft.com/kb/824433 for the Operating System.
Aug 27, 2012 | HP Pavilion dv6000z Notebook
Hp dc5800 recovery cd lost ibought new hd how could i make new recovery partition in the new hd?
There isn't any way to build a new recovery partition on a new empty hard drive. The recovery partition is put on when the drive is imaged at the manufacturer, but you don't have any source to copy from. If you don't have a recovery disc set, you have two options. The first option is to see if HP sells a recovery disc for your computer. It's unlikely, and expensive if they do have them available.
The second option is to do a fresh installation of Windows yourself. This is a little more work, but it's not difficult. You'll need a copy of Windows, the same version that came installed on the computer. (For a Vista machine, you just need the "Anytime Upgrade" DVD, which has all the Vista versions on it.) You'll also need to download any hardware drivers needed from HP's website. The installation is mostly automatic; you just need to enter the product key at some point, and you'll find that on the Windows sticker on the computer case. After Windows is done installing, install the hardware drivers and activate Windows. (When the recovery partition or a restore disc is used, the activation is automatic.)
Jul 31, 2011 | HP Compaq dc5800 Pentium dual-core E2180...
Can i use my emachine recovery disk on my gateway after i install a new hard drive on my gateway?
No, you can't. (Well, it might be possible, but very unlikely, that it would work.) Recovery discs are made for specific machines. There are a couple of reasons why the discs for one system can't be used for another brand or model.
In addition to installing the operating system (Windows), recovery discs also include drivers for the machine's included hardware (video, sound, media card slots, etc.). The drivers on the recovery disc for an eMachines system won't have what a Gateway system needs, unless they were built using exactly the same motherboard and other parts, which would be quite unusual. If wrong hardware drivers are installed, Windows may not start and give you the famous "blue screen of death". Or Windows will start, then begin finding new hardware and asking you for drivers you won't have (although you could find them at the Gateway website). The discs also include the applications the manufacturer preloaded on the system. Some of these may not work and cause problems because of the hardware differences (a sound control program with the wrong sound hardware, for instance).
The other reason is that a restore disc also includes information that gets placed into Windows so the system comes up already activated and ready to go. Activation is based on information about the hardware configuration of the system, and yours won't be correct. Windows will see the this and you'll need to activate manually. If the Windows version on the eMachines recovery disc isn't exactly the same as the one on the Gateway, the product key on the computer won't work when you try activation.
Rather than try using the wrong recovery disc, see if you can borrow or download the installation disc for the Windows version specified on the product key sticker on the Gateway. Then you can do a clean new Windows installation and activate it using the product key. You can find the drivers your computer needs at Gateway's website as I mentioned before. It's more work than just running the recovery disc, but it will work. This does mean the system won't have any of the preloaded applications originally on the computer when you're finished. But this is not a bad thing.
Much of the preloaded stuff on a new computer is often called "bloatware", which you really don't need. It just slows the computer down, uses up Windows resources, and may be gathering information and sending it to sites behind your back. You can find good free programs to do anything originally installed and install only what you really need and want. Here are a few suggestions to get you started:
CD/DVD burning: CDBurnerXP
Antivirus: AVG, Avast!
Audio processing: Audacity
Image processing: GIMP
Office suite: OpenOffice
Good luck getting the system back up and running. Thanks for using Fixya!
Jun 30, 2011 | Gateway GT5670 Desktop PC
I have the disc - i bought it at frys but need to re-load it and lost the key for both office home and student 2007 and for windows xp professional. Can you help me
Unless you can remember the key or find it, you're out of luck. You might be able to bring it into Fry's and ask for a new key. Isn't the key normally on the case?
Jun 24, 2011 | Microsoft Office Professional 2007 Full...
I have a norton security disc but my laptop dont hve the disc drive, how can i install the internet security by entering only the norton product key through the web???
Hi, you can download the Norton Security Suit directly from Norton's webpage, you can use your product key on that installation package.
May 17, 2011 | Acer Aspire One D255-2670
I need the product key for it ... please help!!!
the product key for windows should be on a sticker underneath your laptop' if there isn't one on the laptop or on the packaging for your disc I'm afraid you'll need to ask the computer manufacturer for it
Apr 16, 2011 | Computers & Internet
Microsoft Office Professional 2007 Full Version for PC Logo
Top Microsoft Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
