Question about Bosch 18 in. SRS45E02 / SRS45E08 Exxcel Slim-Line Free-standing Dishwasher
Dishwasher not working.... when i close the dishwasher and turn it on i can not hear any water running and there is a pool of water at the bottom that will not drain
Posted by shaughnessyd on
Richard Morris
    Master:
  • 577 Answers
Hello, How long has your dishwasher been do this? Have you washed dish's in it? Also, these German made dishwasher run on less than 2 1/2 gallons of water. These German manufactured dishwasher machines run really quite. Because of the German water conservancies laws. They limit the amount of water dishwasher and washing machine can use. Also, there is no storage hot water system in there homes, it on demand hot water. You can't hear the motor running and about the only thing one can hear is maybe the water washing the dishes.
Now, the water at the bottom of the dishwasher, if the drain isn't connected up under is the sink drain and trap area or the garbage disposable in the sink. but some place lower on the drain pipe. You will not have a spiffing effect on the the bottom of the dishwasher, it the same with washing machines. One the discharge pump starts sucking air, it will not drain the dishwasher. The siffen effect works if the water is below the outlet for the drain. Example: Home owner have the new washing running and continue fill with water. Why, because the drain pipe end is below the the bottom of the washing machine tub. It fill up with water and siffen action continues emptying the tube will it still filling. One heck of a water bill.
GB...stewbison
Posted on Aug 25, 2011
2answers
Water Pools up in the bottom of our Bosch Dishwasher
sure...did you clean out the bottom filter too? the valve is buried inside that machine...you'd need a detailed service manual to perform this work.
Dishwasher will not drain
If you can close the door, turn the control to drain and, can hear the motor running; you have a clog under the pump screen in the back of the Dish Washer preventing the pump impeller from turning
if you hear nothing: reset the house circuit breaker.
to fix: while the DW is on turn off the DW house circuit breaker then remove the pump screen and, remove the broken glass etc. from the pump then: repower and, test.
My maytag dishwasher lower and upper spray arms are working intermittently. Sometimes there is plenty of water spraying around, other times, I can hear what sounds like the motor running but the arms are...
Pour 1 Cup of Muriatic Acid (Can be purchased at your local Pool Supply Store) into the bottom of the washer and a little in the soap dish. Run the Dishwasher through 5 cycles. Check to see If this helps. If not Try the same process with CLR house cleaner.
Water will not drain after cycles are complete
Start with removing the screws in the bottom of the dishwasher and pull out the filter, etc. Clean everything you remove in a sink and soak in white vinegar anything is coated with minerals.
Inspect closely everything you can now see with a flashlight (watch out for broken glass!) Remove any debris found. Reassemble and test if removing any obstructions found.
If problems continue, run a short cycle and listen closely. When the pump should be running, do you hear the sound/hum of the motor turning (but water is not draining?) If yes, replace the pump motor.
If you hear nothing during the cycle when the dishwasher should be draining, the problem is almost certainly a failure of the timer/controller that controls the pump motor.
Good Luck!
Water pools in bottom of dishwasher and dishes come out dirty
Pump is stopped up, or bad, can you here the pump run, if so drain and make sure there is nothing in the intake of the pump.
1helpful
Water pooling up in bottom of dishwasher
is there any way to run the cycle from the beginning and listen to hear if the machine is draining at all when the cycle starts do you hear the water spraying on the inside ? if not then you have several different possibilities....clogged drain line, pump impeller broken(sounds like running but no action), water just flowing back to washer the last one's an easy fix just loop the excess drain hose up like a reverse "p" trap on a kitchen sink drain this keeps the water from flowing back to the machine
Gaggenau dishwasher model GM- 915-710
i suspect you are hearing the drain pump working due to the antoflood being actuated.
remove the bottom front panel and bottom tray is exposed and it is probably full of water. mop water out and machine will work. if fault reoccurs, then you have a leak
1helpful
3answers
GE Nautilus Drain Problem
I had the same problem (water remaining in the bottom) after the rinse cycle. FYI my GE Nautilus is 7-years old.
(1) I disconnected the drain tube at the garbage disposal unit (in the sink) and, using a wire coat hangar freed a 'plug' of sludge located at the spot where the drain tube clamps onto the garbage disposal. I blew into the drainage tube to further clear other 'plugs' I observed but could not reach w/the coat hangar.
(2) I unscrewed the Filter/Strainer on the inside (bottom) of the dishwasher; and further removed the inner filter; cleaned both out.
(3) Re-ran the dishwasher thru complete wash/rinse cycles (to check for leaks. There were none.
Finally, upon completion of the w/r cycles there will always be a small pool of water (residing in the filter area). However my dishes are clean and (after 7-years) checking the drain tube and filters was a breeze.
Hope this helps
The dishwasher in my kitchen doesn't seem to drain and it seems pump is not working
My motto is "if it ain't broke, don't fix it.", but in this case we will make an acception. Check the inside of the washer for a float device sitting on the bottom. Floats can get stuck or bent over, make sure it goes up and down freely
Bosch 18 in. SRS45E02 / SRS45E08 Exxcel Slim-Line Free-standing Dishwasher Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Michael Thomas
Michael Thomas
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
