Question about Pride Mobility Products Used Jazzy 1120/2000 Electric Wheelchair
I have a Jazzy 1120 the wheel or motor on right does not run smooth, like the other side , it seems like it hesitates for a second,and then runs rough.
Posted by riverrat687 on
Mark Brown
    Filmmaker:
    Uploaded 5 video answers.
  • 168 Answers
Sounds like the motor brushes need replacing.
Posted on Dec 02, 2013
3 Related Answers
Anonymous
SOURCE: Wiring Diagram Pride Jazzy 1120
mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There are two levers just under the seat at the front. Pull the forward and to right to lock position, which will release the gear so that the wheelchair can be move about without any electric power. Bear in mind though that releases the gear, still too heavy to push as normal wheelchair. Give a go, to find out for yourself.
Posted on Aug 28, 2009
Anonymous
  • 7 Answers
SOURCE: The joystick is not sensitive enough, there is a
The Jazzy wheelchairs have programmable controller. This includes the length of the pause before moving, speed, acceleration speed and deacceleration speed. You usually need a programmer to change the programming. You supplier should have one. For your nearest supplier have a look at the pridemobility website: www.pridemobility.com
Posted on Jun 01, 2010
lennieg2000
  • 692 Answers
SOURCE: what are the best batteries
andre Your Jazzy uses 2 Group 24 batteries and I would get MK batteries they are very good and can last 3-4 years if taken care of. Follow their charging recommendations and you should get great service from them Hope this helps you
Posted on Sep 18, 2010
Jazzy 614 HD. Motor runs but the wheel does not turn
hi T. Phelps, sounds like the coupler situated between the motor and gearbox is broken etc.
Regards
Rob
Jan 31, 2016 | Pride Jazzy 614 Hd JAZZY 614HD
No charge no run
could be one of many probs, please provide more info, is there any light when switched on? can you charge the batteries etc. any cracks on the controller and so on.
Nov 17, 2012 | Pride Mobility Products Used Jazzy...
Where is the freewheel lever located on the jazzy 1113?
Original Jazzy Select has push-down levers on each side behind powered wheels. These manually disengage the brakes on each motor individually. They are about 6 inches long and push down an inch or so. I don;t know about other more current models, The 2 smaller wires to each motor disengage the brake when given power (24 volt, I think). The 2 larger wires run the motor.
Jun 17, 2012 | Pride Jazzy 1113 ATS Indoor Power...
The right wheel seems not to be working smoothly. When I try to drive straight it veers to the right slightly, like the left wheel has more more. It is also hard for the chair to turn left because the...
Hi Jack
Sounds Like all you need is for a technition to program you chair. They can do an adjustment to compensate the different strengths of each motor and make the chair run straight Also to improve the turning speed adjustments. Programer is a P&G PP1
Good Luck
mimobility
Apr 26, 2011 | Pride Jazzy 1103 Ultra Standard Power...
I have a Jazzy 1101 that is showing is showing a right motor disconnect code (3 Red & 1 Yellow) I have checked all connections on the chair and have not found any to be loose or corroded. Several times...
Hi. Sounds like a stuck or worn brush in the right hand motor. If one or both of the brushs are sticking, give it a light file on the sides of the brush until it slides in and out smoothly. Be carefull tightening the brush caps, as they can crack if tightened too hard, but they do need to be done up firm. Good luck. Neil.
Jul 16, 2010 | Electric Jazzy 1115 Power Wheelchair
The joystick is not sensitive enough, there is a pause between the joystick movement and the motor response. Jazzy 1120 how to adjust it?
Apr 21, 2010 | Pride Mobility Products Used Jazzy...
Apr 28, 2009 | Pride Mobility Products Used Jazzy...
Pride Mobility Products Used Jazzy 1120/2000 Electric Wheelchair Logo
126 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
