Question about Motorola Mag One BPR40 Two Way Radio
How do you open up a bpr40 to get to a broken circuit board in radio ? It is my personal radio that Motorola service center said was unrepairable so what the heck ? Thank You !
Posted by bentley504 on
steven sikora
    New Friend:
    Problem Solver:
  • 6 Answers
You can use two small screw drivers, one on each side of the bottom of radio. Insert and lift up. Knobs have to be removed. They pull off.[can be difficult] Use a chassis removal tool[6685666D01] that can be ordered from motorola. If the repair shop sent it back unrepairable,you can try sending to motorola.[$134.00 flat rate repair] or just cut your losses. Would not invest any money because it is an inexpensive radio.
Posted on Oct 14, 2013
4 Related Answers
Anonymous
SOURCE: Motorola BPR40 how to clone
How To Clone a BPR40 Radio
Cloning duplicates the contents of your radio (master radio) into the new radio (slave radio). Tuning and alignment information are not affected by cloning.
Set Up the Master Radio
1. Turn off the radio.
2. Press and hold Programmable Button 1 (the top programmable button) and turn on the radio. Keep pressing the Programmable Button 1 until beep is heard twice.
3. Release Programmable Button 1. Notice the LED changes to RED
Set Up the Slave Radio
2. Press and hold Programmable Button 1(the top programmable button) and turn on the radio. Keep pressing Programmable Button 1 until the beep is heard three times.
3. Release Programmable Button 1. Notice that the LED changes to GREEN
BPR40 Radio to Radio Cloning Procedures
1. Connect the cloning cable to both the Master and Slave radio.
2. Press and release Programmable Button 1 of the Slave radio.
3. Within 2 seconds Press and release Programmable Button 1 of the Master radio.
4. The LED for both radios show flashing orange during cloning.
5. Once cloning is completed, an
Posted on Sep 02, 2010
eradiostore
eradiostore
  • 1658 Answers
SOURCE: are my Motorola MagOne BPR40
Yes. They are programmable to either wideband or narrowband on a per channel basis.
Best regards.
Posted on Feb 16, 2011
eradiostore
eradiostore
  • 1658 Answers
SOURCE: re: MagOne by Motorola, BPR40
None of the buttons will solve this issue.
A repeating low tone is heard when you press the PTT if your battery level is low. You may have a bad or poorly charged battery. It takes more energy to transmit than to receive, so the first place this shows up is when pressing the PTT. A quick way to check this is to swap batteries with a known good radio and see if the problem switches to the other radio.
Battery tips: Clean your battery contacts with a pencil eraser to remove the film caused by hand oil. Always charge your battery with the radio turned off. And be certain your charger is plugged into an outlet that is not connected to a light switch shutting off power. Batteries last approx. 2 years. Check your battery's date code to see its age. (3 or 4 digit number, first one-two numbers are the year, second two are the week of the year. example: 1132 would be 2011 the 32nd week)
If the above does not solve your problem, you should see your local Motorola dealer, or a nationwide repair center for more assistance. Current flat rate repair on this style unit is typically around $69.
FYI: Your buttons are likely top button = monitor/sticky monitor and the bottom button could be hi/low power, scan or one of several other features. Each button has a short and a long press option.
Best regards.
Posted on Aug 09, 2011
eradiostore
eradiostore
  • 1658 Answers
SOURCE: How do I connect Mag
The Mag One BPR40 is dealer programmable. You have two choices:
1) Reprogram your CP100s to match the new BPR40s. For this you would need to know what the dealer programmed the BPR40s to... OR
2) Take your BPR40s back to the place of purchase and request they reprogram them to match your CP100s. This should be a free service since you just purchased the BPR40s. They will need to know some settings from the CP100s to make the match.
Best regards.
Posted on Sep 19, 2011
We have 6 Mag one BPR40 radio's all of a sudden you can't hear anything in the ear pieces.
Very strange! Assuming no programming has changed: check that all earpieces are tight into the radio. Unplug, check for audio without an earpiece and replug into radio. Make certain your batteries are FRESH (less than 1 year old) and fully charged. I am assuming you are using earpieces approved for the Motorola radio. Many speakers do not work and several earpieces are not designed well. Stay away from the auction site cheap ones. You get what you pay for, including failures. For several audio jacks to fail at once would be very unusual. Try a new earpiece. I suspect earpiece failure more than anything. All tests after this require checking programming and/or taking the radio apart.
Apr 15, 2015 | Motorola 4 Magone Bpr40 Uhf
How do you synch a set of Motorola MagOne BPR40 radios to a new set of the same radios?
BPR40 radios are dealer programmable using Motorola proprietary software and cable.
Jun 23, 2014 | Motorola Mag One BPR40 Two Way Radio
How do i remove the circuit board in the BPR40
PeteD.
Contact Motorola Solutions.
Get Support
Mark
Motorola Mobility Support
Mar 13, 2014 | Motorola Headset Mic Vl130 Pr400 Bpr40...
Fuse Location on Mag One BPR40
these usually use a diode for reverse polarity protection and no fuses. You will need a full schematic and probably a service manual.
Oct 14, 2013 | Motorola Mag One BPR40 Two Way Radio
Green light stays on bpr40
If this is after programming your radio needs repaired. We see this when some BPR40s are reprogrammed. Take the radio to your local service center or send to a qualified repair center.
Sep 12, 2013 | Motorola Mag One BPR40 Two Way Radio
Have two bpr40 need to find out the frequencys
The BPR40 is a dealer programmable radio. The frequencies would need to be read out using Motorola proprietary software. The only thing you can tell from looking at the radio is whether it is VHF or UHF. Model number AAH84K... is VHF and AAH84R... is UHF.
Best regards.
Aug 20, 2013 | Motorola Mag One BPR40 Two Way Radio
Battery clips
you have to remove the circuit board from the case. There is a rod that holds the clip in. You have to remove a little rubber cover that keeps the rod from coming out.
You need the part number : PMDN4022AR
Mar 21, 2012 | Motorola Mag One BPR40 Two Way Radio
How do I connect Mag One BPR40 two way radio by Motorola to CP100 two way radio by Motorola? I already had about 8 CP100's and we just got 2 new Mag One's. Thanks.
Best regards.
Sep 17, 2011 | Motorola Mag One BPR40 Two Way Radio
My magone BPR40 radio isn't sending when PTT is pushed. It is receiving fine. Any suggestions?
A couple of thoughts:
1) Check the mic hole and see if it is covered or clogged with debris.
2) Does your PTT button seem hard or the opposite, mushy? You could have an internal PTT issue. The PTT is a common failure part on 2-way radios. Feel around for the 'sweet' spot and see if you can make a simple or partial transmission, or if it will even momentarily open up the receiver on the other unit. If so, your radio is in need of repair. It would likely need a new internal PTT. (At most repair centers where the BPR40 is repaired the flat rate repair currently are around $69 for the BPR40)
3) Has any reprogramming been recently done on the radio? If so, double check the programming to be sure your PL/DPL code is set the same as your other radio.\
4) Check your battery. Trade batteries with the other unit and see if the problem changes. It takes more energy to transmit than to receive.
Best regards.
Jun 15, 2011 | Motorola Mag One BPR40 Two Way Radio
Broken battery port
Try this link for parts:http://www.ereplacementparts.com/dewalt-dc011-type-72v-18v-radio-charger-parts-c-1009_2641_7415.html
Feb 09, 2009 | Dewalt DC011 AM/FM Radio
Motorola Mag One BPR40 Two Way Radio Logo
817 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Jane
Level 1 Expert
Muntejaya Ginting
Muntejaya Ginting
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
