Question about Cisco Linksys E1000 WirelessN Broadband Router Network Routers
I have a problem with a laptop computer that is connected to a Cisco router. The problem is that when I try to connect to the inernet I get this page that states that asks for the guest password. Even though I am the owner of the computer I do not remember setting up a guest password to get onto the internet. Is it possible for the guest password to be changed. If not what must I do to be able to get onto the computer?
Posted by raymondsoile on
  • Anonymous Mar 20, 2014
    password
Robert Lissor
    Sergeant:
  • 263 Answers
Go to the control panel and click on user accounts highlite the guest account and on the left of the screen you will have a list of options click on delete password and that should do it for you
Posted on Aug 25, 2011
No wifi on a cisco SRP527W
Try resetting the Cisco.
CISCO/Linksys -To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of the router with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Mar 15, 2013 | Cisco SRP527W Wireless DSL Router
What do I need to make my printer wireless?
You need 1) a wireless router with a USB port that supports the HP OfficeJet printer. 2) The software for your router to run a printer on the USB port. Obviously, you will need a USB A/B male end cable.Note: the scan features of the all-in-one may not work unless the printer is directly connected to the computer. Bi-directional communication is required for scanning and the router software may not support this completely.
Check the list of supported printers closely for older routers. I have a Cisco Linksys E4200 v.2. This router supports all the HP printers that I use.
If this is a new installation of the printer, first install the printer on the computer. If you have Windows 7, just connect the printer to the USB port on the laptop. This will install the OS drivers for the printer. (For Windows XP, go to the HP site and get the full software.)
Next install the wireless router between your modem and computer and set that up. (If you have DHCP (dynamic address allocation), it should be automatic. Otherwise follow the directions.) Next install the router software (for my router, it was Cisco Connect).
My next step was to launch the Cisco Connect program and connect the printer directly to the USB port on the router. In Cisco Connect, choose add a printer and find the printer connected to the router. Print a test page. (At times, I've had to reset the port that the printer is on in the Windows Control Panel Printer Properties. (For the Cisco Connect, the printer is on the DOT4 port.)
Other routers will be set up somewhat differently.
Another option is to have the printer connected to a desktop and then make it a shared printer with the wireless router communicating between the laptop and the desktop. This makes the desktop the print server, so it needs to be on when you want to print. If you have several computers with Windows, this can fairly easy to set up. Make sure that the computers are in the same Workgroup (XP) or Homegroup (Win7). Enable sharing and you are done.
I hope this helps.
(who has a OJ 7000 (with ethernet port) and a LJ1320 (USB) connected to the router. Three computers talk to these printers with the laptop on the wireless network. On an older router that didn't support the printers, the laptop was the server for a previous OfficeJet and one of the desktops was the server for the LaserJet.)
Aug 27, 2012 | HP OfficeJet 6110 All-In-One InkJet...
Reinstalling cisco m20 0n vista
Is it re-installation of complete network or you are just trying to add Vista computer to the network?
Is it a complete re-installation then you can reset the router to factory default settings and then try to reconfigure it.
You can run Cisco connect software on the main computer or you can also reinstall it manually,
Read how to reconfigure router manually,
If you trying to connect Wireless Vista computer to the network then you can simply search for the WiFi and then join the wireless network on Windows Vista computer
Jun 05, 2012 | Linksys by Cisco Cisco Valet Plus Wireless...
Help!!!!!!!!!!!
Leave the user name blank and enter the password admin ( admin once only ).
Try this.
If that doesn't work then search for the Cisco connect software on your main computer. You might have installed the cisco connect software on your main computer while installing your router.
If it is windows computer then cisco connect software might be under All Programs.
If is a MAC computer then cisco connect might be under Applications.
Open cisco connect software.
Click on router settings. You will see the router name and password. If you click on Advanced settings, it will open the setup page.
If nothing is working then you will need to reset the router and reconfigure it.
Remember once you reset the router, you will need to reconfigure it from the scratch.
Click to see more information about cisco connect software
Apr 12, 2012 | Cisco Linksys E1000 WirelessN Broadband...
When I try to access my cisco e1000 router on firefox or google it keeps saying that it is busy and will not connect
Are you trying to access the setup page of the router?
Did you install the Cisco connect software on your main computer?
If you have cisco connect software installed then open Cisco connect.
Go to Router settings. Click on Advanced settings. It will open the setup page of your router.
If the cisco connect is not installed then try to power cycle the router. Unplug the power to the router, wait for 30 seconds. Plug in the power cable. Wait for 30 seconds.
Now try to access the setup page.
If that is also not working then I will suggest you to reset the router and reconfigure it manually.
Watch video.
How to reset Linksys router.
Watch Video:
Linksys router setup
Feb 24, 2012 | Cisco Linksys E1000 WirelessN Broadband...
I am trying to connect using Cisco VPN through my Motorola wireless router, but cannot connect. I check with my internet service provider and they do allow VPN. Our IT division has checked the...
The devices appear to be in functioning order. However, the connection network requires another computer on which signals are directed towards. The computer server on which network resources are acquirable is unavailable. For example, your devices can provide sevices to another computer if any were avialble. Usually an internet provider would allow acess to several computer with subscription. Consult an internet service provider, examples, at & t, T- mobile, Verizon, boost mobile, or consult any available at your local area. www.at&t.com, www.t-mobile.com, www.verizon.com, Goodluck
Jan 11, 2011 | Arris SURFboard SBG900 Wireless Router...
How do i remove devices from the wrt54g v8.2 router
Step 1:
Launch Cisco Connect and select Computers and devices.
NOTE: To launch Cisco Connect on a Windows computer, go to Start > All Programs > Cisco Connect. To launch Cisco Connect on a Mac computer, navigate to the Applications folder in Go, and then start Cisco Connect. For detailed steps in launching Cisco Connect, click here.
From there select computers and devices you want to remove.
Sep 24, 2010 | Linksys Wireless-G WRT54G Router
My cisco linksys router is working with one of my laptop computers. How do I program my other laptop to be compatible?
you shouldnt have to program it to but try going to network connections and manually setting up the connection
Oct 17, 2009 | Zyxel Prestige 334 Router
I have a cisco router linksys. I connect internet cable to it in ethernet port. Neither by wire not by wireless I can connect my laptop. The connection comes as only local
If you can plug the cable that you have ran into your router into your computer directly and it works, then you can plug the router back in. Then connect the computer to the router via cable and unplug the router for about 15 seconds and plug it back in. If you connect the computer by cable directly and it doesn't work, then try unplugging your router for about 15 seconds and then plugging it in. I have found many networking items that need to be reset whenever a network cable is plugged in when the device is powered on.
Jun 08, 2009 | Cisco Catalyst 2908 (WS-C2908-XL)...
Point to Point T1 Using Cisco 2800 Routers?
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Dec 03, 2007 | Cisco (WS-X3011) Router
Cisco Linksys E1000 WirelessN Broadband Router Network Routers Logo
316 people viewed this question
Top Cisco Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Mike
Resolution IT Dubai
Resolution IT Dubai
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
