Samsung HP-R4262 42 in. Plasma Television Logo
Posted on Aug 24, 2011
Hi my Samsung 42" SP42Q96HD
A
Anonymous
This problem is complicated because it involves the ability to diagnose a plasma tv because there are to many possibility's
to this problem . to make it simple there's a short circuit in your tv obligating it to turn on and off now the defective board is dead making a no turn on .
4 Related Answers
Anonymous
  • 106 Answers
  • Posted on Jan 20, 2008
SOURCE: LG PLASMA 42" TV MODEL: MZ-42PZ14 ABLLKS
Check the fuse on Y Sustain Board. If the fuse was gone, replace that board.
Anonymous
  • 608 Answers
  • Posted on Dec 19, 2010
SOURCE: My Samsung plasma 42 "
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
Remember, TVs CONTAIN HIGH VOLTAGE AND CAN KILL YOU! Do this at your own risk.
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found online. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and if it does please rate it accordingly. Good luck.
A
Anonymous
  • Posted on Feb 10, 2011
SOURCE: I have a Samsung 42 " Plasma Model no: PS42Q96HD.
Hi, this could be a problem with the power supply in the tv, it is common especially on some Samsungs and specific repair kits are available quite cheaply if you have good soldering skills.
Usually this is caused by capacitors that have dried up and split, you can normally tell as the capacitors are bulging on the pcb, you can get them in a kit as I said eBay sometimes do them or you can buy them indivually from a good electronics components supplier, make sure you get the correct values for each!! marked on the side of the capacitors in xx/x V, xxx/x uF and 105oC. (the x's represent numbers)
The picture below shows the type of theing that happens, the brown ones are bulging/split on the top whereas the black one is fine.
High Voltages can exist in these sets, never attempt anything while plugged in and
if in doubt do not attempt it yourself and seek the advice of a qualified TV Technician.
gopakumarg43
  • 76851 Answers
  • Posted on Sep 03, 2011
SOURCE: Samsung 42" Plasma #SPR4212X/XAA TV was
Hello
In normal casses, if the power supply regulator board of Plasma Ts cannot be get repaired by any means. The inverter transformer [Switched Mode Power Supply]; will get shorted windings inside it, which cannot be retifed. this is a critical part, that cannot be available at local electronic sparepart market, of as part at Samsung service center. it is best to replace it as card basis, as plasma power supplies must be very right in every respect for the proper working of the plasma TVs. Thie is quite normal case also, that unlike LCD power supply sections, plasma power supplies will get troubled soon, as it supplies more current to the plasma screen to illumitate. Just replace it. You can get it from the Authorised Service Center for Samsung at your town. It will solve your TVs problem. The oscillating frequency of the switched mode power supply of this model of TV you owns have [350kHz] a very high frequency than normal LCD or other Samsung power sections. It will have a high stability, which cannot be accuired by normal service techniques, and components in it will be of special type. OK.
Samsung plasma tv #pl42b430p2d volume turn up &down itself
hi the v+ is dirty or just bad maybe every taster
2helpful
6helpful
Sometimes Loses Sound
disconnect the hdmi cable from both ends it resets the sound signal!!!
Buzzing noise from 42 inch Samsung Plasma TV
this is a comon occurance in theis model it is caused be loose laminants in the switching tranformer sometimes it can be fixed by covering it with clear GE silcone
HP-T4254, 2years old, turns off and on by itself, started occasionally doing and recovering by itself, now, have to keep it unplugged as it does it from the git-go.
Hi my name is Roety,
I hope I can help you with your issue ,
Sounds like you need a new mainboard.
Make sure you match it with the correct model/version number
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
