Question about General Electric Microwave Ovens
I have no electricity. I just recently purchased a GE Hotpoint propane stove/oven. The model # is RBG745BEA2CT. I realize the clock and such will not work without electricity, but can I still use the stove anyway or does this model function with electricity??? How do I light the burners? There is propane to each burner, but they will not light with a clicker or match.
Posted by lorilee907 on
  • General Elec... Master
  • 18,378 Answers
You must have electricity for that unit. The ignitors are electric and so are the valves.
Posted on Sep 08, 2017
5 Related Answers
beltronic205
Gerry Harvey
  • 1481 Answers
SOURCE: I have a kenmore stove whose burners wont light.
If the gets give no gas then sounds like a Thermocouple, this is a device that allows the gas to come on after a period of time ensuring that the pilot is lit and heated up this thermocouple, once it heats it then allows gas to enter and ignite the main burner..hope this helps ,please leave feedback.
Posted on Apr 12, 2010
Anonymous
  • 1478 Answers
SOURCE: I have an Amana ARG7600W
If one of your burner heating elements works only intermittently, it's probably because of worn or bad contacts in the receptacle that the element plugs into. you can remove the element by lifting it up several inches and firmly pulling it away from its attachment (receptacle). Read your owner's manual to learn the correct technique for your range. If, after removing the element, you see that the ends of the element that were plugged in are pitted, corroded, burned, scarred, or rusted, replace both the element and the receptacle.
Take care.
Posted on Sep 26, 2010
rockmeister
Rockme
  • 2047 Answers
SOURCE: Got a problem with my
Usually the indicators are powered by sensors which are often triggered on by the heat sensor on the burner. When the burner got burnt the indicator was most likely triggered on when the burners shorted out. And therefore got damaged in the process. When the unit was repaired most times repairers do not take note of the little details such as this as they have checked the full system and know that all is well.
The indicator does not mean any of the burners are on but is on as a result of the sensor being spoilt and last signal sent by sensor is on. As an off signal has not been sent the light cannot go off unless the sensor is replaced.
hope this explanation has been helpful?
Posted on Jan 26, 2011
Whispis2
Whispis2
  • 192 Answers
SOURCE: All the burners are turned
This is dangerous.
You should be able to stop it by unplugging the stove. The automatic spark requires electricity to work.
Unplug it and leave a comment with the make and model and I will assist you in finding a replacement.
Posted on Mar 31, 2011
Ironfist109
Iron
  • 3018 Answers
SOURCE: Own a holiday brand stove
  • Holiday appliances are made by Maytag. Here is the link to the Maytag parts list.
  • http://www.maytagpartsonline.com/index.php?main_page=index&cPath=1251_1279
  • There are some burners and element for sales as you go through the parts. This is the absolute best I can provide without a model number. However, being a Maytag, it should be much much easier with the parts list from Maytag I provided. Maytag range parts are universal throughout their models.
Regards, Tony
Posted on May 17, 2011
How do I get a manual for a Hotpoint over-the-stove microwave?
Hotpoint is part of the GE company. Manuals can be printed off GE's site in the appliance customer support section.
https://www.geapplianceparts.com/store/
Feb 26, 2015 | GE Hotpoint Over-the-Range Microwave
How do I change the fuse?
On most GE/Hotpoint models, the control panel assembly will either tip down, or pivot sideways for access to the components behind it. Screws holding the top air deflector might have to be removed in order to gain access to the control panel mounting screws. I recently junked-out a similar model. The main fuse was near where the power cord enters the cabinet on top. Avoid contact with any of the high voltage components.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
May 07, 2014 | Hotpoint RVM1325WW Microwave Oven
Would like to learn how to set the clock on my GE stove.
You can download GE owner's manuals and installation instructions here.
We're
happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Jun 06, 2011 | General Electric Microwave Ovens
Hotpoint bd35 electric oven instruction manual
Here is a link for you to download a PDF instructional manual for your Hotpoint cooker or Hotpoint oven.
how to use this service
1 click on Link,
2 click manufacturer (Hotpoint)
3 enter your model number and download the PDF file .
http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do
Jan 28, 2011 | Microwave Ovens
Clock frequently goes blank and needs to be reset
You have a faulty display module due to one or more components leaking. Some models have a seperate display module that can replaced without the complete board having to be replaced. If not, the board needs to be replaced. You need to ask your spares suppliers that have info. on that model.
May 21, 2010 | Hotpoint RVM1325WW Microwave Oven
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Hi I have elcetric hotpoint oven. I did sef-cleaning and after that I am not able to unlocked the oven. What should I do?
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
You can download GE./ Hotpoint owner's manuals and installation instructions here.
Oct 10, 2009 | GE Hotpoint RVM1535 Microwave Oven
Hotpoint RVM1535DMCC OTR micro-has NO stove top draft.
Did you check the installation instructions and the owner's manual?
here.
If you still have a probme, I would call the GE Answer Center:
GE Answer Center®
1-800-626-2005
Monday - Friday: 8 a.m. - 10 p.m. ET
Saturday: 8 a.m. - 7 p.m. ET
Closed Sunday.
Mar 05, 2009 | GE Hotpoint Over-the-Range Microwave
My micowave oven purchased 12-15-07 from Lowe's. The exuast fan will not come on, I press the touch pad key and it reads low and when I touch it again it reads high but the fan does not run.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
GE Customer Service is here.
(Just for the sake of discussion, have the stove top lights gone out recently? Quite often they will short, causing fan or light trouble.)
Aug 03, 2008 | GE Microwave Ovens
Microwave Ovens Logo
42 people viewed this question
Top General Electric Microwave Ovens Experts
William Miller
William Miller
ray gallant
Are you a General Electric Microwave Oven Expert? Answer questions, earn points and help others
