Question about Braun Health & Beauty
I have a Braun Thermoscan model hm3 that I bought in 93. My thermometer changed from fahrenheit to celsius and I don't know how to switch it back.
Posted by breinke71 on
Claire Smith
I found this online and I used it to help me with the same issue. It also works for f to c. You will need something small to help you though.
Posted on Jul 02, 2014
5 Related Answers
jayghale
  • 4 Answers
SOURCE: How do I go about
Replacing the batteries - Using the tip of a ball-point pen, press the battery door lock to open the battery compartment - Using your finger, press the battery release - Remove the batteries and replace with new batteries, making sure the poles are in the right direction - Slide the battery door in until it snaps in place
Posted on May 19, 2011
pretzelp
  • 10 Answers
SOURCE: Can you change the temp
Turn off the thermometer
Press and Hold the L/O Button
Continue to hold the start button when the F or C display appears. Watch for these displays to cycle over the display window.
Release the start button when the F display appears on the screen.
5
Listen for a beep and watch for the Braun ThermoScan ear thermometer to shut itself off, indicating that you changed the temperature scale to Fahrenheit successfully.
6
Follow the same procedure but release the start button when C shows on the display to switch from Fahrenheit to Celsius.
Posted on Feb 28, 2011
nobodyoukno
SOURCE: I have a Braun thermoscan type 6022, but code po5
It's not po5, its pos... you're not positioning it properly in the ear canal.
Posted on Feb 21, 2011
jayghale
  • 4 Answers
SOURCE: I would like to change my ThermoScan from Celsius
Changing the temperature scale from F to C: - - Turn on the thermometer - If the unit is already on, make sure it is not in the memory mode - Press the ?/MEM button and keep it pressed. Then press and release the activation button to switch over to the "change temperature scale" mode. - By pressing the activation button again, the opposite scale will be activated. Each further pressing of the activation button rotates the measuring scale
samflynn
SOURCE: I have a Braun ThermoScan Type6013 have changed
ive the same problem. it has new batteries and been cleaned but still reads lo or a low temperature. why?
Posted on Apr 26, 2012
How do I change my thermos IRT6500 to fairenhete
Changing your Braun Ear Thermometer from Fahrenheit to Celsius ...
? 1:02
https://www.youtube.com/watch?v=tV0-PYayGUs
Dec 6, 2013 - Uploaded by kapil kumar
E-Commerce the new and expedient shopping trend took the world to its storm in a very short time. Without ...
Kaz.com - Changing your Braun Ear Thermometer from Fahrenheit to ...
? 0:55
https://www.youtube.com/watch?v=fApQTzCgMPg Jan 25, 2011 - Uploaded by Helen of Troy- Health & Home
Helen of Troy- Health & Home. ... A helpful video from Kaz.com that shows you how to change your Braun ...
Changing Temple Touch Premium Fahrenheit/Celsius Option - YouTube
? 0:49
https://www.youtube.com/watch?v=262vWnmHD0A Jan 4, 2010 - Uploaded by TempleTouchMom
How to change your Temple Touch Premium thermometer's operating scale from fahrenheit to celsius and ...
How to Change a Braun ThermoScan Thermometer From Celsius to ...
https://healthfully.com > Health This means that even parents of babies who cannot safely hold a thermometer under their tongue can still determine if their child has a fever. A quick scan of the ear produces the temperature in seconds, not minutes. These thermometers have readouts in both Celsius and Fahrenheit scales. You can switch from Celsius to ...
[PDF]ThermoScan ThermoScan - Braun
www.service.braun.com/line/PD/D6026/D6026_4_PL.pdf 6. Changing the temperature scale. Your Braun ThermoScan is delivered to you with the Celsius (°C) temperature scale activated. If you wish to switch to Fahrenheit (°F), proceed as follows: Make sure the thermometer is turned off. Press and hold down the «start» button. After about 8 seconds the display will show this. change my thermos IRT6500 to fairenhete Google Search
Mar 18, 2018 | Cars & Trucks
Change temperature setting on Forehead Thermometer
no I contacted customer service, this thermometer reading ONLY in F, there is no option to change it to C
Jan 25, 2014 | Braun Home
I would like to change my ThermoScan from Celsius to Fahrenheit but I am not sure what buttons to push to achieve this
May 06, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
How do I change my Braun ear thermometer back to F from C
You did not provide a model number however the Instruction Manuals for the various Braun Thermometers can be found here:
http://braun.kaz.com/kaz/service/prodResult/
Not sure if this procedure is common to all but this may work otherwise find the manual specific to your model number.
This thermometer is shipped with the Celsius temperature scale activated. If you wish to switch to Fahrenheit ( °F), proceed as follows:
Turn on the thermometer. ( If it is already turned on, make sure it is not in memory mode.)
Press the /mem button and keep it pressed. Then press and release the activation button to switch over to the «change temperature scale» mode.
By pressing the activation button again, the Fahrenheit scale is activated, «°F» is displayed on the LCD. Each further pressing of the activation button toggles the scale between °C and °F.
Release the /mem button to return to the ready symbol . The temperature stored in memory will automatically be converted to the selected scale when displayed on the LCD.
Apr 24, 2011 | Braun Thermoscan Pro 4000 Ear Thermometer
Can you change the temp reading from F to Celcius on a Braun Thermoscan 6014?
5
6
Feb 28, 2011 | Braun Health & Beauty
Need to convert C to F
Changing the temperature scale Your Braun ThermoScan is shipped with the Fahrenheit (°F) temperature scale activated. If you whish to switch to Celsius (°C) and/or back from Celsius to Fahrenheit, proceed as follows: (1) Make sure the thermometer is turned off. (2) Press and hold down the Start button (IRT 4020) or the «I/O» button (IRT 4520). After about 3 seconds the display will show this sequence: «°F» / «SET» / «°C» / «SET» ... (3) Release the Start button / «I/O» button when the desired temperature scale is shown. There will be a short beep to confirm the new setting, then the thermometer is turned off automatically.
Feb 16, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
How fo I change the degrees from C to F degree ?
Feb 10, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
Have a braun thermoscan and want to change it from F to C degrees lost manual
From the manual of the thermometer:
This thermometer is shipped with the Fahrenheit temperature scale activated. If you wish to switch to Celsius (°C), proceed as follows:
• Turn on the thermometer. (If it is already turned on, make sure it is not in memory mode.)
• Press the /mem button and keep it pressed. Then press and release the activation button to switch over to the «change temperature scale» mode.
• By pressing the activation button again, the Celsius scale is activated, «°C» is displayed on the LCD. Each further pressing of the activation button toggles the scale between °C and °F.
If this isn't the right manual, go to: http://braun.kaz.com/kaz/service and select your country from there.
May 16, 2010 | Health & Beauty
Health & Beauty Logo
3,221 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
T.Johns
Level 1 Expert
bigcheapskat
Level 1 Expert
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
