Question about Schlage Camelot Deadbolt Keypad, Satin Nickel #BE365VCAM619
I CAN'T REMEMBER MY 6 DIGIT CODE AND CAN'T FIND MY MANUAL, I WANT TO RESET IT, CAN YOU PROVIDE ME WIT INSTRUCTION?
Posted by chrisallen35 on
Coaltowner
  • 963 Answers
How can I program my electronic keypad lock when the instructions with the programming code have been lost?
The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This number is the programming code referenced in the information for changing the entry code.
This link will take you to the page that you need to get started:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Then scroll down to this heading on that page:
Electronic Security-Keypad Deadbolt BE365
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This installation video (second item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery! Batteries should be replace about every three years.
The seventh item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that programming code that you found on the backside of the keypad.
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
http://get.adobe.com/reader/
Good luck--and please provide feedback if this helps!
Posted on Aug 25, 2011
Factory reset sony experia acro (so 02c) from power off?
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Dec 19, 2012 | Cell Phones
Forgot password
Dec 02, 2012 | Cell Phones
My brother locked himself out of his phone, couldn't remember it and forgot his gmail account to sign in. Now I have to work it out. Can you please help me?
Nov 03, 2012 | Samsung i5503T GALAXY 5 Android 2.1 Touch...
I forget my lock code i do not reset my fon ples help
Sep 16, 2012 | Cell Phones
I forgot my security code
Aug 08, 2012 | Nokia 5130 XpressMusic Red Unlocked Import...
Ican't remember my loce code?
Aug 04, 2012 | Nokia 5800 XpressMusic Smartphone
I forgot my password20
Jul 26, 2012 | Cell Phones
How to unlock screen code
Jul 26, 2012 | HTC Cell Phones
By accident a friend closed my trunk notrealizing that it would close by itself = I lost the owners manual and do not remember how to reset the system can you please help
If you know the 5 digit code to unlock your door, press the 5 digit code followed by the number 6. This will pop the trunk. To change the unlock code, press the 5 digit code, followed by the new code you wish to use. Keep in mind, the new code will be lost if the car should lose power and revert back to it's original code.
Jun 03, 2011 | 1993 Lincoln Town Car
Schlage Camelot Deadbolt Keypad, Satin Nickel #BE365VCAM619 Logo
639 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
Mike
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
