Before assuming it needs to be recharged with refrigerant gas, check the following. As all of these things can affect the cooling,
1. Remove and clean the air intake filter.
2. Check exhaust hoses for obstructions.
3, Exhaust hoses may have to much downward droop. Which doesn't allow the air to exhaust as it
should.
4. check for holes or leaks in the exhaust hoses. Repair or replace the hoses as needed.
5. Check the temperature setting on the controls, as it may be set to high.
If none of the above solves the problem, it may need to be recharged with refrigerant gas. hich is best left to the pros.
I hope this helped you and thanks for choosing FixYa.
