Question about Jabra Stone Bluetooth Headset
Just recieved my jabra t820 in tha mail and it will not turn on or charge even though it is on the charger and the thing is plugged in. can you help me?
Posted by bookitha on
Wesley
    Scholar:
  • 58 Answers
Some Bluetooth headsets will take a while, but if you have had it plugged in for a decent amount of time and still are getting no reaction, you may have received a defective unit. According to the Jabra website, you must notify the company from which you purchased the unit to receive a refund/replacement if this is the case.
Source:
http://www.jabra.com/na-us/support/pages/warantyinfo.aspx
Posted on Aug 24, 2011
Jabra extreme2 will not charge
All things can go defect. But to find out if it is your charger, cable connector or the battery you have to look very close. Perhaps you even try another charger and or try to charge an other headset.
When you are using this one for a couple of years now, day by day, perhaps it is time to start saving for a new one?
Jul 21, 2014 | Jabra Extreme2 Bluetooth Headset
Why can't I turn on my Jabra sport after charging?
Could be. No battery has a lifetime forever. But perhaps you did not unplug it correct?
Try plugging it in and look if any light goes on when plugged in on the charger. You don't need it on the charger for a long time. Then unplug it an try to start it again. also check if all contacts on the Jabra and on the charge cable are clean and nothing can block the current.
May 23, 2014 | Jabra SPORT Earset
Manual for jabra t820
To pair the Jabra with a Verizon Wireless phone, the phone must have Bluetooth. Bluetooth allows a device to communicate and transfer data with another Bluetooth device without having to be physically connected to it. The instructions for connecting the Jabra with the Verizon phone vary slightly depending upon your phone model. Jabra headset instructions don't vary per model.
Jun 19, 2012 | Radio Communications
Jabra 5050
Sounds like you've used this thing quite a bit, eh? Rechargeable batteries only last for so many charges. If a charge doesn't last very long anymore, you probably need to change the battery. This is not for the technically challenged. The battery may just pop out of a slide cover, or may require practically breaking the device in half to get it open, then unsoldering the old battery and resoldering a new battery in place.
But, it definitely sounds like you need to replace the battery. You may have to consider a new one - sorry.
Apr 21, 2010 | Jabra SP100 Bluetooth Wireless Adapter
I have the same problem. Do you have a solution
I have the same problem with my Jabra pendant. However even though the red light goes out, it still seems to be charging. Leave it connected for about 3-4 hrs and see if the battery is full.
Mar 26, 2010 | Jabra BT350 Bluetooth Headset Headset
I have a jabra bt250. I put into the charger one
A search on here will get the answer I found it once it. is the battery and headset needs to be opened and 'jumpstarted' it is non replaceable though.
Sep 24, 2009 | Jabra BT250 Consumer Headset
Jabra a 210 adapter not charging
I contacted Jabra and they said this problem is due to a bad internal battery. There is nothing that can be done to fix it. So I returned it to the guy who sold it to me and got my money back. Purchased another from a different vendor, and this one works great. That's the only solution!
Oct 13, 2007 | LG Jabra A210 Bluetooth Adapter for...
Canon SD30
Defective product return it for a replacement
Sep 08, 2007 | Canon PowerShot SD30 / IXUS i Zoom Digital...
Not sure if Jabra bluetooth headset or charger that not working
I had the same problem, called support, they told me battery is defective or too old and doesn't accept the charge. Battery in a headset is hardwired and can't be replaced, so the whole thing is trash :(
May 26, 2007 | Jabra BT250 Consumer Headset
Jabra Stone Bluetooth Headset Logo
731 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Robek Thirtysix
Robek Thirtysix
Level 1 Expert
Mosaub Al Masri
Mosaub Al Masri
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
