Question about Hitachi 51F59 51" HDTV Projection Television
Http://gethuman.com/phone-number/Hitachi
800-448-2244
numbers to call
They call you instead
No waiting on hold. Free.Call free via web
Don't waste minutes.
#1
The #1 phone number and #1 way to reach customer service according to Hitachi customers here at GetHuman. Compare all options
Average Wait: 14 mins - 24 hours, 7 days
Posted on May 23, 2015
SOURCE: Hitachi 50EX20B Bigscreen TV
You can download a PDF from here: http://www.servicemanuals.net/results.aspx?type=SM&brand=0&model=50EX20B Make sure that the coolant is not leaking out onto the printed circuit boards. i have had the remote sensor cause this problem before and also I have had bad capacitors in the sweep and the main power supplies. Good Luck
Posted on Jun 14, 2007
SOURCE: Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Posted on Jan 05, 2008
SOURCE: Have a panasonic 47" HDL
3 blinks means the convergence circuits are shutting the set down. Usually the convergence ICs will take care of the problem, but I would recommend getting the service manual from the following link, as they will provide you free support to help you diagnose why it wont start as usually the convergence ICs wont prevent a set from powering up, unless another component in the convergence circuit has failed.
http://servicemanuals.vstore.ca/
Posted on Mar 24, 2008
