SOURCE: My SONY HD projection TV KDP-51WS550 (2005)
Hi, 5 times blink of standby light shows that TV needs White Balance adjustment. No need to dump it, adjustment is also not so difficult. Let me know if you want to give it a try to guide you.
SOURCE: Sony Wega kdf-50E2000 Keeps turning off and on
Before you replace the lamp I recommend trying to clean/dust the lamp component and lamp plug in area. I had the same problem and was able to resolve it by simply blowing the dust off the lamp components and fan. Use a can of high pressure air to get into the cracks and crevices.
SOURCE: HL-R5667W Picture just went blank, no sound. When
two things to check here:
1. remove the lamp and examine it to make sure it is not shattered inside.
2. if the set had a high pitched or fan like noise before it failed, the color wheel needs to be looked at--I can tell you a easy way to do this.
Look at the lamp first--life span is 2000 hours.
I am here to help and the more you tell me the better I can help you.
SD TECH Steve
Testimonial: "Thanks. I will look at the lamp and the digital board."
