Question about Xerox Phaser 8560MFP Laser Printer
Phaser 8560 printing fuzzy. Machine menu screen illuminated but no display can not access onboard help due to screen failure
Posted by kent154 on
Steven C
    Director Badge:
    Uploaded 100 video answers.
  • 160 Answers
The cause of the blurry prints is that oil, from the maintenance kit, has leaked onto the drum encoder assembly. The drum encoder is responisble for position the Y-Axis or vertical direction of the print. The oil on the encoder is making the printer incorrectly position the drum as the pinthead is spray ink onto it, thus you get a blurry print. If you look closely, letters probably have a downward jag to them.
There are two ways to fix this. The cheapest and easiest method is to remove the right side cover, then the fan on the right. Behind that fan is the drum encoder wheel. Using a lint free cloth and isopropyl alchol (preferably 99%), clean all the oil off of the sensor disc. This method might work for a while, but the problem will ussually come back.
The second method would be to just replace the drum assembly. The drum assembly comes with a new encoder disc.
The display (menu screen) can easily be fixed by replacing the control panel (part# 848K06552). It's pretty simple to replace w/ no tools required. Here is video to show you how.
Posted on Aug 31, 2011
How do I print on 4X6 photo paper on the Xerox Phaser 8560
To print 4 x 6 on a Phaser 8560 you can only use the MPT and you can't duplex. When you load the paper into the bypass, the screen will pop up options for paper size and type. The closest match to 6 x 4 is A6 but the tray will know that the size is wrong if you select it. Therefore, you must select 'Custom Size' and input the size in whatever units the printer requests, either inches or millimeters depending on your printer settings.
Hope this helps.
Nov 28, 2010 | Xerox Phaser 8560MFP Laser Printer
My xerox phaser 8560 is printing muted color
First off on your screen access troubleshooting, and perform the remove light strips and also remove smears and skips.
Next go to Xerox.com, under support and drivers enter 8560 in the search box. then go to the support page.
You want to look up the procedures for TEC color correction. And follow those steps.
If you are using a generic ink then, all bets are off in getting true color reproduction.
Feb 10, 2010 | Xerox Phaser 8560DN Printer
Phaser 8560 error is print head out of position, how do I correct this problem
There are 2 problems that usually cause that.
1 is if you have had a power failure , or even not, the print head wiper blade tacks to the print head and does not allow it to move.
The other thing is the Print Head Block, a stainless steel block, about 1 inch square, located on the lower portion of the left side of the machine is contaminated with some ink and not allowing the print head to move freely.
Jan 12, 2010 | Xerox Phaser 8500/DN Printer
Xerox phaser 8560 nvreset - how?
According to http://www.laserquipt.com/support/idx/42/615/article/-Reset-the-Printer-to-the-Factory-Defaults-NVRAM-Reset-.html (and it worked for me):
NOTE: Resetting NVRAM returns stored parameters in the image processor board NVRAMto their factory default values. The print count and the Adobe firmwareserial number are not affected by this reset. You can reset the PostScript NVRAM using the Service Tools menu or the Service Diagnostics menu.
To reset the printers NVRAM using the Service Tools menu:
NOTE: Print a Configuration Page before resetting NVRAM.
Pressand hold the [Up] arrow button on the Control Panel, and then press the[OK] button. This will automatically display the Service Tools menu onthe Display Screen.
  1. Press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Reset NVRAM], and then press the [OK] button.
To reset the printers NVRAM using the Control Panel:
  1. Pressthe [Up] or [Down] arrow button on the Control Panel to select[Troubleshooting] on the Display Screen, and then press the [OK]button.
  2. Press the [Up] or [Down] arrow button to select [Service Tools], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Reset NVRAM], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main screen.
In answer to the clarification request, I suspect they have lost the admin password. Does that help you answer the question?
Jun 03, 2009 | Xerox Phaser 8560DN Laser Printer
P/N FOR pHASER 8560 DISPLAY PANEL
P/N for Phaser 8560 printer is 802K93650
Apr 21, 2009 | Xerox Phaser 8560DN Laser Printer
Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Apr 15, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8560 display error
There is a known issue with that display. Call 1-800-835-6100 and tell Xerox you have a problem with the diaplay, They should replace it free.
Jan 26, 2009 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8560 Will Not Power On
The 8560 has a one year warranty. Call 1-800-835-6100 and they will come out and fix it.
Aug 07, 2008 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8560 Waste INk
Although I agree totally, the anwer is no. Althought it appears black, take a piece of it an use it like a crayon. It is a combination of all the color inks combined. So if you take and rub it on a piece of paper it will be a purple color. So threfore would not create proper colors.
Now to save ink, Do not turn the printer off at all. Just let it use its own sleep mode. The power consumption is intermittent to keep the print head warm and uses about the same ammount of electricity as your refridgerator light bulb. The reason being, when you turn off a solid ink printer, it purges the print head of ALL old ink and dumps it into the waste tray. That is part of those weird noises you hear when you cycle up the machine, one is a compressor emptying the print head.
Also, honestly, althogh I am not sure what you are using the machine for. But you would be wise to put that product on a pay per page maintenance agreement. That includes all ink and all service. Some of the parts for those printers are super expensive.
I will say one thing you can do with that waste ink, if you know anyone who has children, they can use them as purple crayons..
Feb 21, 2008 | Xerox Phaser 8560DN Laser Printer
Xerox Phaser 8560MFP Laser Printer Logo
726 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
