Question about Audiovox AVP-7000 Video Cassette Player - 12 Volt Car Video Player
We have a Audiovox VCR player that we ordered from Ebay for our RV but did not receive cables and we cannot find cables for it that works with the TV. Why is it different?
Posted by logangloria on
Anonymous
Mine has normal RCA jacks for Audio/Video & cable TV ports in & out. I do not understand your problem unless it is the Console wiring. Look into console (original set was for Toyota Van). Unit easily removed & cable can be snaked directly to units.. I took my console apart for components which use less space using direct power lead in with fuse & radio shack plug & a short cable TV jumper for signal from VCR to TV
Posted on Oct 21, 2011
The Audiovox Rca RCRN04GR Universal Remote Control
Try to Google the model numbers of each for "manual" to see if available.
I have a v8p4000 does the cord have to be plug up to the screen as as the player in order for the system to work
on mine, the screen/speaker module plugs into the player/base. note the power switch on the upper right side of the screen; this must be on as well as the main power on ( left side of the base). connect the power supply, power on; no other external connections are needed.
the screen can be detached and used as a low quality monitor; connect a/v cable & power supply to the right side of the screen, connect the other end of the a/v cable to vcr or whatever.
1helpful
Dvd play works but vcr playing does not
For this unit the component output (green, blue, and red cables) only work for the DVD player portion of it. You will need to connect either the av input on the back or the front with composite (yellow, red, and white cables) to your television in addition to the component cables I assume you have connected already. Once you have done so you will need to switch this unit over to the right av output in order to access the vcr and also switch your television over to the right av input in order to pick up the signal from the vcr.
2answers
I have a 30 year old tv w/cable. I want to install a dvd/vcr combo player. What kind do I need? I've tried one and it didn't have the right connection.
If the original TV doesn't have audio/video inputs, you'll need a DVD/VCR player that has a built-in RF modulator. A RF modulator takes the audio & video and modulates a RF carrier to one of the channels that your TV can receive. In the U.S., this is usually channel 3 or 4. If the DVD/VCR player has a built-in tuner, connect your cable to the RF input of the DVD/VCR player and the RF Output of the DVD/VCR player to the cable input of the TV. This way, you can receive your cable channels through the DVD/VCR player and watch movies as well. If your DVD/VCR player does not have a built-in tuner, you can put a RF switch inline that will allow your TV to either receive the cable signal or signal from the DVD/VCR player.
- Jim
Sound problems
TRY PUTTING A SET OF PHONO CABLES INTO THE VCR INPUT THEN TO THE ANALOG OUT PUTS ON TOUR DVD/VCR SWITCH AMP TO VCR PRESS DIGITAL INPUT BUTTON ON FRONT OF AMP UNTILL YOU GET _ _ _ SET SOUND TO PROLOGIC 2.THIS SHOULD WORK.
HOPE THIS HELPS.
CABLE GUY.
4answers
Where to buy a USB Cable for Opal
Try eBay... an acquaintance of mine needed one and patiently (!) waited for one to show up on eBay for 99 cents plus shipping.
You have to understand that the USB cable for this particular model of MP3 player is uniquely wired and isn't in wide circulation as a replacement.
I'm putting some tunes on it for him right now and it seems to work, even though I'm using a Mac to put the files on it. Seems simple enough, just drag and drop the MP3 or WAV files on it. It won't work with AAC formatted files, which is too bad, since you can get many more songs onto a device when using properly formatted AAC files and they still sound fine, well fine for an MP3 player anyway!
Audiovox AVP-7000 Video Cassette Player - 12 Volt Car Video Player Logo
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Michael Thomas
Michael Thomas
Richard Lilja
Richard Lilja
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
