What operating system are you using?
Are you using windows xp, vista or 7?
Thanks!
If you experience this error during install you need to run the Windows Installer CleanUp Utility. To download the Windows Installer CleanUp Utility click here (link to Microsoft website). Once you've downloaded the utility, Also check if there are remaining folders or files remaining for the program you are trying to install check the programs and features in the control panel and check the C:\Program Files Directory for any folder possibly related to the software and uninstall or delete them. Hope this helps!
I see that you are trying to install a Hot Synk from the cd-rom and it is an .msi file.
You must have a program that can read a .msi file if you system does not have a program that can do so you may have difficulties running the file .msi.
This file from the CD if I may ask did you create the disc using a program or a tool to make a back up of this .msi file?
If not then you can try a different disc with the same .msi file on it see if it will do the same thing, this can be a disc error or a file error if you are using the correct program to run the .msi file you have.
You mentioned a network error occurred as an error when trying to run the disc, make sure you are hardwired when doing this to your Palm because doing this wireless will really give you an error.
This can be a bad file on the disc a bad disc, or a program needs o be used to be able to run and read the .msi file on the disc, also check the conenctions make sure it is hard wired when doing the process thanks.
This is the CD that came with the hardware. I had this same problem in 2005 and someone was able to walk me through what must be done to load the software onto my computer with a VISTA operating system.
Sandra Money
I have had this same problem before and an expert was able to enable me to overcome the error without any difficulty. If you can not do so, please refer me to someone who can.
Thank you.
Sandy
It now works. Thank you.
