Question about Digidesign Mbox 2 Mini Workstation
When i plug in my mbox mini 3 the blue light come on, but when i try to lauch pro tools it says that hardware is not recognize. When look at the mbox mini control panel, it says that it is not connected as well. Also, if i click the phantom in the back the red light on the front just blank frequently.
Posted by nelsonddn1 on
Fred Yearian
  • Digidesign Master
  • 5,603 Answers
Assuming you are on a Windows system, go to Control panel/Sounds and devices/ and check that the Mbox2 appears as the default in the Audio and also Voice tabs/panes while unit is connected. If it is not, select it in each... if it is not in the list offered, then the drivers have not been installed for the Mbox.
Posted on Aug 24, 2011
  • 1 more comment
  • nelsonddn1 Aug 26, 2011
    hey fredy2, i'm actually using it on a mac system...if you know how to do it on there as well that would be greatly appreciated!! Thanks too!
  • Fred Yearian Aug 26, 2011
    We are a PC type here... however you might "translate" the idea to the Mac world... someplace there will be in the setup of the computer a place to define whether you are using the internal audio system or an external system. It has to be there someplace and that is where to look. In the PC world we have to make sure drivers are all there and then we have a list of devices from which to select as default... There must be a similar thing for the Mac, and that is where to look...
    thanks i really do appreciate the help and advice!!
Not working, power is on but nothing is coming up in the screen
The embedded software on board is not booting up. It may have detected a hardware problem. Make sure the power supply is in good condition then disconnect everything else and try again. If fault remains, its toast.
Dec 16, 2013 | M-Audio AXIOM PRO 61 MIDI CONTROLLER
Sound pops an crackels how do you change fse on mini mbox
Fuse would have NOTHING to do with the problem. Make sure to use balanced audio lines... XLR or TRS to mics or other devices.
Aug 24, 2011 | Digidesign *mbox2...
Im trying to connect my mpc 2500 with pro tools 8. im using an mbox 2 pro as my interface. I can get pro tools and the mpc to sync...but i cant seem to understand why i cant hear any of my samples from the...
Check if the Mbox2 has an echo setting that echos the audio from its input. If you want the audio to loop through the PC then it will have to echo there instead. Check that in "Sound and devices" of the PC are all set to transfer via the MBox for voice and playback instead of the internal PC audio system.
Apr 12, 2011 | Akai Mpc2500 Music Production Center
The recording level to my Mbox is very low for some reason. I am running Pro Tools LE and I have a shure 87a microphone. Every time I attempt to record a track, the input volume is incredibly low...
Make sure you turn the Phantom power on the Mbox2 on as the Shure 87A requires it being a condenser mic.Make sure you use XLR mic cables. These are just things to check on.
Jan 29, 2011 | Digidesign *mbox2...
I have a compaq v2000 and what Im tryin to do is conect my Mbox mini and the Xenyx 1002 to the laptop is that posible ? how can I do that ?
Should be possible. For system safety electronically, power ALL interconnected equipment from the same receptacle/plug strip. Use Balanced lines, either XLR or TRS wherever possible.
Dec 15, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
My oxygen 49 3rd generation (m-audio) midi keyboard just stopped working for me. Ive tried changing the usb lead, and I've tried it on a different computer, and it still doesn't work. I have a macbook pro,...
If the keyboard is lighting up, there is a 90% chance the problem is in the software in your MAC.
Hint: Software "breaks" easier than the hardware !!!
Re-install your software as a first step.
Sep 12, 2010 | M-Audio Oxygen 49 USB Midi Controller
How can i connect a behringer eurorack to a mbox 2 for protools
basic speaker cable from the eurobacks speaker output to the di selection on mbox... in one of the input slots
Jan 15, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
I have a behringer xynyx 1204,and a protools personal studio,with mbox2 mini,and im just wondering if its possible to plug the mic into the mixer,instead of the mbox,and still be able to record vocals into...
It is possible, you can simply put a Y-cable for Mic or a splitter for the mbox and the Mic. You can plug the mic directly to the mixer then the other jack on the splitter connected to the mbox.
Jul 25, 2009 | Behringer Music
Digidesign Mbox 2 Mini Workstation Logo
1,387 people viewed this question
Top Digidesign Music Experts
Marvin
Marvin
Are you a Digidesign Music Expert? Answer questions, earn points and help others
