Question about Orion HCCA 275G4 Car Audio Amplifier
I had recently bought the orion hcaa 275G4 and was gonna hook it up but i didnt see a spot on the amp for the remote turn on wire. So was wondering the best way to hook it up? Also i have in my car a 2 amp wire kit from previous system and was wondering if it would be fine to just hook it up to the orion amp without the extra rca's and use the two power and ground wires?
Posted by carpimail on
3 Related Answers
Anonymous
  • 11 Answers
SOURCE: Orion 275g4 Hcca amp
this actually could be your amp...try turning the gain down slowly and you will hear the bumping either stop or become morelike music background thanmusic foregroud. i had this problem with an older amplifier and i fixed it by getting a larder power/ground wire size and decreasing the gain a little.
Posted on Sep 06, 2007
Anonymous
  • 631 Answers
SOURCE: Orion HCCA 275g4 amp
Owner's manual
Posted on Sep 29, 2008
Anonymous
  • 84 Answers
SOURCE: For da orion 2500d, what would be the difference
I honestly would go with 2 12 inch dual 2 ohm subs and wire them one per amp. That will give you a 1 ohm load to each amp and will give the HCCA's 2500 rms per sub... It will be stupid loud... 10s hit tighter than 12's usually and 12's tighter than 15's but u will get more air movement out of a 15 than the 12's and 10s... but... 2 10's require say a 4 cubic foot box to perform well... 2 12's require a 5 cubic foot box to perform well and 2 15's require about 7 to 10 cubic foot to perform to their fullest... no matter what if you put a sub in a box that's too small it will not perform or sound like what you want it to... go 2 12's and like a 5.50 cubic foot box or a 6 cubic foot box and you will love it...
Posted on Dec 13, 2009
Hi were can i find a schematic diagram for orion hcca 275r Thank you
i am looking for the same manual. Did you have any luck finding it?
Mar 22, 2011 | Orion HCCA 275G4 Car Audio Amplifier
For da orion 2500d, what would be the difference between 10'', 12'', & 15'' orion hcaa subs besides a matter of price and inches? I have two of the orion 2500d amps and am ready for the subs. I would...
Dec 01, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Sub making horrible thumping garbage sounds
you need an noise filter in line. It's been a few years since I've had a system but I had the same problem. High power amps like the one you have can actually pick up on the electric pulses from your ignition system. I think I got mine at walmart, or auto zone, somewhere like that. Their pretty cheap too. I don't remember how its hooked up, but If you know how to hook and amp up, this should be no problem.
Jun 23, 2009 | Hifonics Zeus Z400 Car Audio Amplifier
How do i hook my Orion CS-500.5 up to my car?
first if its the stock stereo or even one you bought run rca and blue(remote)wire to amplifier groud amp to chsis of the car make sure to sand it down to make contact then run your positive +wire from your batterie to your amp+
Mar 15, 2009 | Orion CS-500.5 Car Audio Amplifier
Power wire keep blowing fuses
you need to go tho a block fuse which will be able to handle more load but will still give way before the amp its self would get fried i recommend a 75 fuse or higher
Feb 21, 2009 | Orion HCCA 275G4 Car Audio Amplifier
Orion hcca 12d subwoofer wiring
I had two of those they are awsome subs! anyway your best to connect them in parallel that is both positive wires connected together and both negative wires connected together then connect pos and neg to amp in a bridged configuration if its a 4 channel amp - this will put your subs under a 2ohm load and make sure you turn down gain and set your filter to low pass (very important!) turn up gain in increments till your happy :) rock on!
May 04, 2017 | Car Audio & Video
No power to pioneer 5300 amp
ur remote wire needs to be hooked up to the spot marked remote on the amp....and ground to the ground slot..if that is done check the fuses on the amp or check the fuse under the hood from your power wireif it still wont come on..make sure ur ground is touching a good metal area sand around the area if needed this should sole ur problem
Jul 27, 2008 | Car Audio & Video
Sep 03, 2007 | Orion HCCA 275G4 Car Audio Amplifier
Amlifier not working
connect your remote turn on and your problem will be solved
Sep 23, 2006 | Crunch BlackMaxx BLX2000D Car Audio...
Car Audio & Video Logo
Top Orion Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Joe Taylor
Joe Taylor
FastHarley
FastHarley
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
