Question about Texas Instruments TI-30XA Calculator
How do use the ti-30xa to raise 1.02125 to the 8th power
Posted by sbrandau1440 on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Press
1 . 0 2 1 2 5 y^x 8 =
The y^x button is located just above the divide button.
Posted on Aug 24, 2011
How do you calculate 40th root on TI-30XA Calculator?
Raise to the 1/40 power. For example, to calculate the 40th root of 2, press 2 y^x ( 1 / 4 0 =
1.009 to the 17 power and higher
The TI-30Xa has a "y^x" key located just above the divide key. To calculate 1.009 to the 17th power, press 1 . 0 0 9 y^x 1 7 =
The initial population of a town is 2800, and it grows with a doubling time of 10 years. Whay wi the population be in 12 years
The population doubles in ten years so the annual growth is the tenth root of two. The growth in twelve years is the annual growth rate raised to the twelfth power.
The tenth root of two is about 1.0718 . That value raised to the twelfth power is about 2.2974 . Multiplied by the initial population of 2800 gives 6433.
On the TI-30XA press 2 2nd [xth-root] 1 0 = y^x 1 2 * 2 8 0 0 =
2helpful
How do i multiply 1.04 to the 5th power using the TI-30XA calculator?
To raise 1.04 to the fifth power, press
1 . 0 4 y^x 5 =
y^x is the key just above the divide key.
IS THERE AN EXP ON THIS TI-30XA.
Use the y^x key just above the divide key..
For example, to compute two raised to the third power, press 2 y^x 3 =
5helpful
2answers
I need to raise e to a power on my TI 30XA Can you help? Thanks! [email protected]
Put in the number, press 2nd [e^x], then =
[e^x] is the shifted function of the LN key on the top row of the keyboard.
2helpful
How do i do superscript on a TI-30XA?
To raise a number to a power, use the y^x key just above the divide key.
4helpful
Does the TI-30XA have a sign to raise the number to a power of 4 or 5?
There's a key marked y^x (y-superscript-x) to raise a number to any power.
1helpful
How can i raise to a negative power on TI-30xa
Use the Y to the x key [Y^x]. To enter the negative exponent use the change sign key [+/-] not the regular minus - sign.
Hope it helps.
2helpful
How do you do this exponent?
If you mean 3 raised to the power 375, sequence is
y to the power x (under OFF key)
375
Answer is "error" because the result exceeds the 9.9999.... times 10 to the power 99 limit of the TI-30XA
3 to the power 209 is about as far as you can go....
Texas Instruments TI-30XA Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Ekse
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
