Sports afield 6040 executive vault how to reset combination
Spot Afield safes default code is 1,2,3,4,5,6. Open the safe door, with door open lock the handle. This will let you have assess to your things if you have trouble while setting the codes. To change the code, press the * 6 times. You should hear a single beep and one flash from the LED, then enter the default code 1,2,3,4,5,6. Again you should hear one beep and see one flash. Enter the new code you would like to use ...lets say 6,5,4,3,2,1. You should hear one beep and see one flash. Enter the new code again 6,5,4,3,2,1. The code should now be set to 6,5,4,3,2,1. Try the new code and see if it unlocks the door. Also try the old code to make sure it no longer works.. If at any time during the process you hear 3 beeps and flashes something went wrong. You will need to start over.
Good Luck!!
