Panasonic Lumix DMC-FS6 Digital Camera Logo
Elisa Corona Posted on Aug 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My camera felt in the sand, so only tiny particles entered to the eye. The zoom does not work when it is on, there is not a clear image. when I turn on the camera. its lens protection does not opens and a message appears saying that there is a system error (zoom) . What can I do to fix it ands not buy another camera.
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
  • Posted on Aug 23, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2200904
Points
38521
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
How do I get the lens barrel to slide smoothly?
The lens you seem to be referring to is the14-42mm.these were the basic consumer kit lens and has a tendency to allow dust and debris to enter via the rear element/ mount.this is relatively easy to access and fix.you need to have a small Philips screwdriver some QTips and a fine paintbrush or blower.whilst the lens is facing down on flat surface...remove the four screws that hold the mount to the lens body.remove the electrical contact strip screws...you have to be careful and slot the electric contact through past rear mount whilst gently lift up the mount so as not to break the ribbon cable.you should see a small metal cog on pin .check slot position when zoom is closed..then this can be removed and inspected for sand and dust particles.brush anything off the cogs.inspect the internal cog ring whilst turn zoom slowly for any debris.clean and remove any particles.reinsert cog after you zoom closed and return cog to correct position.check if the zoom is now smoother.feed electrical contact back through rear mount re screw.always keep rear cap on lens when not in use.never travel to beach environments as you will most certainly introduce sand into the mechanism.if the lens is still jumpy then it is likely debris has entered within the deeper mechanics of the zoom mechanism.this is much more fiddly to do ...I think YouTube has some strip down tutorials on similar lens.good luck!
JZ300 Autofocus not working
Beyond sand getting in, the lens may have been damaged from the impact if it fell on the lens while extended. It may need to be serviced by a technician.
2answers
Camera will not take pictures. Message on screen says: System Error Zoom I have not had any problems with zoom. How do I fix or clear this message. Thanks, Marsha
Please follow the steps:
1. Ensure batteries are fully charged.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine.
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec... in not done the press both Menu & self time key for 2 - 4 sec.
After all of this if you not success then its a lens error.The lens stuck from the inside becasue the lens guide pin is damaged or out of guide line. In this case you have to replace or repair the camera lens.
Hope helps; keep us updated and remember to rate this answer.
Jun 16, 2011 • Cameras
1helpful
Just need a manual foor Nikon One.Touch Zoom 90s
Description: Sleek and stylish, the exciting new Nikon One-Touch Zoom 90QD offers real zoom power in a lightweight, easy-to-use design. The One-Touch Zoom 90QD has a sharp, clear, 2.5x zoom lens with a 38-90mm range and a macro mode for shots as close as 11 inches. The One-Touch Zoom 90QD features a built-in automatic flash with five versatile modes (auto flash, anytime flash, flash cancel, slow sync and red-eye reduction). The active infrared autofocus, infinity focus (for landscapes and faraway subjects), real-image zoom viewfinder and fully automatic exposure control all help to ensure clear and balanced photos.
7444ca6.jpg Depth 2.1 in. Film Type 35mm Width 4.6 in. Height 2.5 in. UPC 018208018789 Battery Type 1 x 3V Lithium Battery (CR-2) Weight 7.84 oz. Self Timer Yes Camera Type Point and Shoot Focus Type Autofocus Minimum Focus Distance 1 ft. ISO Range - Automatic Setting ISO 100 - 800 Red Eye Reduction With Red Eye Reduction Zoom Size 2.4 Auto Exposure Yes Min Aperture f10.5 Waterproof No Max Aperture f4.8 Zoom Lens With Zoom Lens Zoom Range 38 mm - 90 mm
User Manual can not be found up to now. Very soon will be available.
My lens won't zoom back in!and i can't get it to turn on..
Use your vacuum cleaner to **** out the dust or sand particles stuck between the body and the lens casing. Since the lens is nt moving the camera does not power on.
1helpful
Zoom problem Hi, my Samsung S1070 camera won't zoom in and starts making noises & won't shut down or zoom out again, and the vision gets all blurry! what to do?
You have sand or some other small particles trapped between the moving parts of the lens. But I don't recommend you to try to clean it! Because you need to disassemble the camera and if you don't set the lens as exactly as it should be, the images will be blurry forever!
Whenever i on (start) camera ,Zoom Nikkor is not opening
Your guess maybe right.
If your camera is of SLR type then you can easily open the lens and give it a vaccum blower to blow dust.
If it doesn't work or your camera is compact type then you have to seek help of good mechanic.
Sand in focus/zoom ring
You have to disassemble complete lens assy for cleaning.
5helpful
3answers
Zoom Error
We had this problem for about 2 weeks, we discovered that having the camera auto retracted after the "ZOOM ERROR" message, giving the camera couples of light slaps (slap the camera's LCD side and aim the camera down), this fixed the camera right away
3answers
The SMART ZOOM is not working - doesnt either come up in SET UP menu?
I fixed my problem myself. Simply read the top of the camera1.gif where it says TO USE SMART ZOOM SET IMAGE SIZE TO LESS THAN 2.8M
Then go to the very bottom button on your camera (there are three) and press it and reset your image size.Then your zoom will work.
Problem solved.
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
