Question about Digidesign Mbox 2 Barebone
Mbox 2 pro green power light is blink - Digidesign Mbox 2 Barebone
Posted by steve_amen on
3 Related Answers
Anonymous
SOURCE: all the lights are on on my Mbox. it wont be recognized by pro tools. help!!
Heres the solution !!!!!!
http://www.digidesign.com/index.cfm?navid=54&langid=100&itemid=28900
Posted on Apr 06, 2009
Anonymous
SOURCE: how do i open the mbox 2 pro?
M-Box 2 Pro- 2 small black screws under rubber "feet" on the bottom(back)- 1 shiny screw under "CE" sticker on bottom- 10-12 small black screws under the faceplate sticker= DUMB- then one more small army of small black screws to get the faceplate off the metal casing-(remove carefully as there is a small ribbon connector from the faceplate to the chassis-pull up on small black sides where it connects to the faceplate.)- pop off top- reveals about a dozen small shiny screws holding the two "mother boards" together-left off there because I only needed to get to the volume resistor. good luck with the rest. good design too Digidesign.
Posted on Aug 03, 2009
Anonymous
SOURCE: Mbox 2 and new macbook pro
my Mbox isnt being found by my mac. when i try and install protools it tells me the mbox carnt be found. i have tried different usb cables ect but nothing seems to work.
Posted on Nov 13, 2009
How do i open the mbox 2 pro?
I just opened mine.. it had 5 screws on either side just under the blue plastic cover. if u want to do it nice, then just locate the screw by puttin somethin in there, and use ur screw driver to make a nice hole just above that screw. i really couldnt find an alternative way to open that damn thing.
Mar 27, 2009 | Digidesign Mbox 2 Pro FireWire Audio/MIDI...
Protools mbox2 issue
it doesnt sound like its the mbox more maybe the protools install. But as far as the cable goes can you tell me if you can ping the mbox throught the 1394 connection. If you cant ping it then damage may have been caused to the unit and it may need to be serviced. I fix my own M-box's but in my store it only costs around $50usd to fix almost all problems with a mbox2
Sep 22, 2008 | Digidesign MBox 2 External Sound System
Jul 22, 2008 | Digidesign Mbox 2 Barebone
Mbox 2
dkjkjd jheuj'y je
Jun 13, 2008 | Digidesign Mbox 2 Barebone
All the lights are on on my Mbox. it wont be recognized by pro tools. help!!
un plug it uninstall the mbox and all the asio drivers. update protools. then reinstall the mbox and all the asio drivers you should be fine.
Feb 12, 2008 | Digidesign Mbox 2 Barebone
PROBLEM KEEPIN MBOX 2 CONNECTION TO MAC LAPTOP
I have the same problem. Usually it will work when I reboot the computer. The trick is once you get the mbox working with the phantom power on, is to not turn off the phantom power during your session; the duration in which you use the mbox at that given time before shutting it down. You can switch the phantom off and it won't shut off, but if you press it back on, it may and for me more than half of the time it does shut off. I have a new problem with my mbox. I can't hear play back, even though I can hear sound from either input. Any suggestions?
Oct 26, 2007 | Digidesign Mbox 2 Barebone
Digidesign Mbox  2 Barebone Logo
915 people viewed this question
Top Digidesign Computers & Internet Experts
Marvin
Marvin
Lee Hodgson
Lee Hodgson
matt
matt
Are you a Digidesign Computer and Internet Expert? Answer questions, earn points and help others
