Magic Sing Along Consumer Microphone Logo
Question about Magic Sing Along Consumer Microphone
I bought my Wow Magic Sing from Astro Vision at Virra Mall GreenHills Philippines in 2006. Now my microphone does not work. I suspect there is a problem with the mic cord which is not detachable from the mic or with the adapter. The unit does not power at all.
Posted by cooljoe_10_2 on
5 Related Answers
night71
Lyle Siemens
  • 328 Answers
SOURCE: Worn out wires
I found this shop on the net.
http://www.webbyshop.com/shop/pid213/enter-tech-magic-sing-rca-cable.html
Posted on Oct 30, 2007
Anonymous
SOURCE: vocal problem
i have the same problem but i can't seem to find a solution to this.. does anyone have any advise?
Posted on Feb 06, 2008
Anonymous
SOURCE: Magic Sing EG-18000 Microphone Delay
Your problem is your connection to the TV and maybe your Magic Sing configuration.
Can u specifically describe how you have it connected?
Posted on May 04, 2008
mikeymiddles
Michael Mittelsdorf
  • 58 Answers
SOURCE: batteries were left in the magic sing main microphone.
First, You should know that a leaking battery does not always mean any electronics the battery fluid has touched is ruined.  Quite often, depending on the severity of the leak, most battery fluid spills can be quickly and easily remedied with a few common household items, and maybe a trip to the electronics or hardware store.     Most alkaline batteries store their electrical charge in a chemical device, the battery cartridge.consumer electronics (AAA, AA, C, D, AND 9VOLT)  batteries are composed of alkaline electrolyte of potassium hydroxide and zinc powder and a chemical insulator between the two nodes.  Over time, alkaline batteries are prone to leaking potassium hydroxide, a caustic agent that can cause respiratory, eye and skin irritation.  When a battery leaks usually the cathode or + end with the raised button will leak the caustic potassium hydroxide fluid into the battery case of your microphone.  The battery fluid can cause a lack of conductivity on the battery terminals of your microphone and sometimes the circuitry also.     SOLUTION: First collect these items,   Rubber gloves.  The latex tight fitting type for protection from the caustic potassium hydroxide. Cotton swabs. You can use the small double ended cardboard type found in any drugstore or pharmacy.  A good electronics store will have long wood handled cleaning swabs (usually single-ended or one swab per wooden stick) if you need more reach inside to clean the compartment..  A small cup or can.  Warm water.  Baking soda. Paper towels or napkins. very fine sandpaper (400 grit or higher) or emery cloth.  dish soap. cotton swabs. an old toothbrush and clean , lint free rags. a blow dryer Open and disassemble the microphone as much as possible without disconnecting any soldered wires.  The idea here is to access ALL the surfaces of the mic so they can be cleaned of the caustic potassium hydroxide.  Make a nice solution of about one cup of warm water with one drop of dish soap add one tablespoon of baking soda. Stir well. With your gloves on, use the baking soda solution to clean the terminals and surrounding areas where the fluid has spilled. Use swabs, cotton and towels with the solution to clean the terminals, the surrounding areas and any circuit boards of the spilled fluid.  Do this as soon as you discover the problem, otherwise the powerful corrosive effects of the fluid will cause iron and zinc oxides (rust) to form and these will require a more aggressive approach, namely abrasives. If there are any rust like deposits left after cleaning with the baking soda wash use the blow dryer to completely dry everything.   Sanding should be kept to a minimum but is sometimes "a necessary evil".  The idea is to clean the nickel chrome battery terminals and NOT remove their nickel chrome from the spring-steel battery holder/terminals.  You want to clean the terminals, not remove so much material that the conductive plating is also removed or the battery doesn't fit because the gap filled by the battery is enlarged.  You just want to clean the chrome surface of the battery terminals of your device.  Make sure the unit is clean and completely dry before installing new batteries.  re-assemble your device if necessary, load new batteries and power up!    This is a common repair for any unit which has been stored with old batteries, or if exposed to prolonged heat  or humidity. Store all battery powered devices, especially transmitters, or remote controls in a cool, dry, place, removing battteries if stored over 6 weeks.    If this solution provides no repair, it would be reccommended to seek the Manufacturer's authorized repair center nearest you, or just replace the unit.
Posted on Dec 11, 2008
Anonymous
  • 6 Answers
SOURCE: Cord broken for Magic sing microphone
If you need a cord or any accessories please contact or email me at [email protected] i'll be glad to help you.
Posted on Mar 12, 2009
My wow premium karaoke does not load
hell l your problem seems to be its out of FRECUENCY and is not aligned if you turn it on a lamp in the reception must lit
if it doesnt thats the problem of course the baterries are new right
your antonio
4helpful
2answers
Magic sing mt14k vocal assist doesn't work on any of the songs? We're supposed to hear background vocals, right?
how can I started playing the magic sing I dont have my instruction manual, I tried to hook into the tv but it doesnt work
2helpful
2answers
Change from PAL to NATSC
hi there...try this
1. turn mic off
2. press and hold 8, then press power button (to change to NTSC)
press and hold 9, the press power button (to change to PAL)
Mr. Sean A. DelCarmen
Customer Service Dept.
In A Jiffy Ent. - Wow Magic Sing
1081 EDSA Balintawak
Quezon City 1106 Philippines
[email protected]
NO BACKGOUND VOCALS
Hi im joe,
Regarding your concern the ET 3000 magic sing does not have background vocals at all. The manufacturer design the magic sing for sing along purposes only but they are now improving there future products to have that feature with background vocals.
ED-9000 freezes
try removing the song chip( if your using one)
test the mic with its built in songs...
if it works- then the problem is on the song chip- try cleaning it......
[email protected]
1helpful
2answers
Perfect score every time even when intentionally trying to do bad
The service center in California has the pack to upgrade (fix) the scoring in ET-13000 and most likely other models, including the ET-18000. They can be contacted at 1-714-578-0004.
I had mine upgraded by the place where I purchased it (MagicSingMall / www.magicsingmall.com) in New York (phone # to call is 1-212-561-5919). They might be able to repair units purchased elsewhere - give them a call to find out.
Good luck & God bless
3helpful
3answers
Magic sing
hi i am working in Wow Magic sing- one of the magic sing distributor in Philippines. Is your unit wow , even if its our competitor, the manufacturer is just the same.
kindly give me more detailed information about the model and description. please be more specific.
please try to remove all song chips- if there are any...inverted and dirty song chip wont make the microphone turn ON.
check the cable and cord- open (loose connection) cord or open adaptor will not make it work as well.
Top Magic Audio Players & Recorders Experts
W.L.
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Are you a Magic Audio Player and Recorder Expert? Answer questions, earn points and help others
