Panasonic KX-TG4500 Phone Logo
Question about Panasonic KX-TG4500 Phone
I have the Panasonic KX-TG4500 4 line cordless phone system. It was purchased new in April '07. I have replaced the base unit battery once since. \r\n\r\nCame in on Monday to a slowly flashing display, "O: Base Set date & time." Tried to push Menu button to access the menu for resetting date & time. It didn't work. Checked for dialtone, none. Called in from cell phone to see if the base unit would ring. No ring. Tried the reset button on the bottom of the base unit, still doesn't work. Tried to unplug the power, and plug back in, then push the reset button on the bottom. No help. Also tried a different power cord from one of the handsets and reset button on base unit. Still doesn't work. I have tred everything I can think of except for replacing the base unit battery, and buying a new power cord (heavy duty) and then a complete reinstall/reboot. Ideas anyone? Would a dead base unit battery cause the system to not work if the power cord was still working? Thanks for any help extended.
  • Anonymous Oct 26, 2011
    I bought a new battery and generic power cord thru Amazon. The battery was only a year old, and it should last about 2yrs. Anyway, while waiting for the battery to arrive, I tried rebooting everything and was successful in getting the base unit to work. I now have an extra backup battery and power cord on hand if needed. I'd advise anyone who has one of these systems to keep a backup battery for the base unit and handsets on hand. No one had them locally.
Anonymous
    New Friend:
What did you end up doing? i have the same problem.
Posted on Oct 25, 2011
I have an old phone KX-T3000H and I need parts for it . Cap for the battery on the phone and another battery cap for the base . Does anybody know where can I purchase them.
That type of spare is not normally available on phone sets. I guess you could contact Panasonic.
Cordless & Corded Replacement Parts' Panasonic US
shop.panasonic.com > telephone-replacement-accessories
Handset Charger. PNLC1046ZW. Replacement Handset Charger for select Digital Cordless Answering Systems. Does not include AC Adapter or Handset.
Official Panasonic Cordless Phone & Corded Telephone ...
shop.panasonic.com > cordless-corded-telephones > cor...
Shop Panasonic cordless and corded telephone accessories from batteries, headsets, replacement parts and more.
Panasonic Telephone Parts and Accessories
panasonic.encompass.com > modelbrowse > MSC
Panasonic Telephone from Encompass parts & accessories. ... and Accessories. Panasonic Replacement Parts ... Cordless Phone With Answering Machine, 7.
1helpful
Is there 3 way calling on this model?
[PDF]Operating Instructions - Support - Panasonic
service.us.panasonic.com/OPERMANPDF/KXTG2740S.PDF
PanasonicModel No. KX-TG2740S ... other cordless phone. For Best Performance. 3. For assistance, please call: 1-800-211-PANA(7262) ... •If you use the handset near anothercordless phone's base unit, noise may be heard. .... 2-Way Radio Communication .....&Each mailbox icon will flash if there is at least one new message in the.
Panasonic Product Support - KX-TG2740S
shop.panasonic.com > Get Support
PanasonicObtain product support for Panasonic KX-TG2740S 2-Line 2.4GHz MultiTalk Expandable Cordless Phone System with Digital Answering System.
2answers
How can i register my hanset. it says error.
Please use the below link to assist you with handset registration.
http://service.us.panasonic.com/OPERMANPDF/KXTG5621S.PDF#page=35
Panasonic KX-TG6700 Phone
test the adaptar if working try it in another phone
2) sure the the line cord is plugged firmly in the phone base
3) unplugged the phone base . Wait from 30 seconds, and plug it again. Allow up to one minute for the cordless handset and phone base to synchronize.
4) charge the batteries by 16 hours aprox.
5) if the batteries is completely dead can take 30 minutes before low battery appears on the screen.if doestnot work replace battery by new ones.
try agan.
I have a Panasonic kx-ta824 system that has been up and running for 3 years,flawless the cordless phones are dropping calls so I replaced them with 2 new ones, they are doing the same thing. The corded...
The problem sounds like it is the main base, the only advice I can give is change the phone cord between the base and the wall to see if that will help, the only other option is check the base for connection issues "inside the unit" and finally check your phone company and ask for a technician to find out if there is issues with the phone lines. If you still have problems, try a replacement base.
9helpful
3answers
It said base no power
Remove then replace the batteries from the hand set. You should now get dial tojo.
It always losing the line during the cordless calls
* CHECK YOUR AC OUTLET WITH NO LOOSE CONNECTIONS.(remove multi adapters mostly caused problems)
* FULLY RECHARGE THE BATTERIES.
* CLEAN DE BATTERY CONTACTS IN & OUTSIDE THE HANDSET & THE BASE UNIT.
* IS THE BATTERIES DON'T GET CHARGED FULLY IN OVER NIGHT.PLEASE REPLACE THOSE.
* REPLACE WITH ONLY RECOMMENDED RECHARGEABLE BATT"S.
* PLACE THE BASE UNIT AT CENTRALIZED AREA FOR THE MAXIMUM HANDSET RADIATION.
* KEEP THE BASE UNIT AT SAME FLOOR.
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Top Panasonic Lands Phones Experts
Marvin
Marvin
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
