When the battery is fully charged, please put it in again. That means, if it is still in, remove it once again.
Switch it on, and even if you don't see a thing try to make a picture.
Then press the display button several times, to see if anything comes on the screen again.
If the camera does not respond after that, you should go back to the dealer, of contact Nikon.
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success
I assume that there is no power on the camera when the lens gets stuck. Please try the following: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Please follow the troubleshooting given below to resolve the issue: (a) Turn off the Camera and remove the Battery then press and hold the power button for 30 seconds. (b) Then, reinsert the Battery and turn the Camera ON. Please make sure that the Battery is fully charged. (c) Next, press and hold the Reset button for 30 seconds located above the DC-in jack on the Camera using a sharp pointed object.
If the Camera doesn't operate normally even after performing all the above mentioned steps then service will be required.
If you turn it on in photo review mode the lense will not open so turn it on in photo capture mode or if dirt gets caught in the lense it would jamm it shut so try to clean it, or if the lense is dented it would jamm, or if at one time the lense tried to open indide a case or in a position where the lense was blocked the motor mioght have burned out or the gear that pushes the lense out might have broken, in the case of the last three answers then a specialist might be able to fix it , or you might need a new camera, (i reccomend a fujifilm)
The problem is
1- some dirt somehow got on the outside of the lense. After it was retracted fully in, it prevents the camera from opening again. When you turn it on, if it opens a little bit, try to pull it out NOT too hard and let go a few times. If it opened, clear the outside of the lense. Your camera should be back to normal.
2- If you droped the camera, you probably damaged or dislocated a mechanical part of the lense. You may have to take out the lense by unscrewing it and inspect it for damged parts or disconnected cable. Make sure clean the lense and test it by moving it in and out a few times, before puting it back on the camera.
