Question about Brother XL-2610
I bought a new Brother XL 2610 about three months ago and with a number of medical issues, my wife is only now able to begin use it. While going through the manual and checking a number of online forums, I understand this model should come with the 'automatic needle threader'. Is this correct, as it our machine does not have it? My thanks in advance, Ian Ross
Posted by rossenrode on
las91158
    New Friend:
  • 4 Answers
No. The manual in the box is for several models of machine. One version is a 26 stitch, the other 35. You probably have the 26 stitch model, which does not come with a needle threader.
Posted on Jul 23, 2012
5 Related Answers
bargainbox
Hassy
  • 1388 Answers
SOURCE: Needle Threader is not lined up
This is called the Needle Threader Plate.
If this is too small for you to read, or you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 24, 2008
Anonymous
  • 8 Answers
SOURCE: the needle threader has stopped working
Check you needle size. On my machine the needle threader does not work with the smaller needles, 9/65 and 11/75. The eye of the needle appears to be just short of the hook on the needle threader. I have no problems threading needles in larger sizes.
Good luck,
SewReady
Posted on Nov 12, 2008
mohammed387
mohammed marika thambi
  • 1952 Answers
SOURCE: Janome MC 10001 auto. needle threader stuck in up position.
You are threading the top of the machine incorrectly.
Make sure the needle is in correctly with the flat side to the rear of the machine, make sure to thread the upper and lower portions of the machine correctly. If this does not solve your problem, please respond.
Posted on Feb 12, 2009
Anonymous
  • 11 Answers
SOURCE: needle threader is not working bernina 220 activa
Use a magnifying glass to see if the little hook in the needle threader is bent so that it is not going through the eye of the needle. You might be able to gently bend it back with tweezers.
Make sure that your needle is in the upper most position when you try and the presser foot is down.
Posted on Mar 17, 2010
paj42
  • 1116 Answers
SOURCE: AUTO THREADER CAME OUT
When you activated the threader, the needle was down and the threader came off or broke.
If it is not broken, you may be able to push it back into place.
Turn off the power and tip the machine back on some towels so it does not slip and with a flash light check the area where it fits and see if you can get it back into position.
If not, will have to thread the needle the old fashion way.
Check with your Brother dealer to see if they can look at the machine while you wait.
They may be able to get it back together or they will have to replace the threader.
It is possible they will have one in stock, or they may have to order it.
Posted on May 01, 2010
I'm having a problem threading my brother sewing machine model XL 3010
1. Clean up any loose thread in the bobbin area.
2. Pull on the bobbin thread while it is out. It should give a tension that is equal to the top tension of three. You'll have to approximate. Adjust the screw tension on the bobbin. It is the screw nearest to the thread exit hole on the side.
3. Put it back in.
4. Now, the top tension should be at about three. If it still allows a little wad on the bottom of the fabric you can adjust the top tension by tightening a small amount and monitor each time you adjust. The wad should go away.
Oct 05, 2016 | Brother Sewing Machines
Brother L5-21215 manual
Hello, GO to this website for the manual that you need: Support Center
May 20, 2014 | Brother XL-2610
The light on my machine does not go on and it's not working.
If it is a new machine for goodness sake...READ YOUR MANUAL.
Mar 19, 2013 | Brother XL-2610
First time on Brother XL 2610, threaded correctly but thread will make loops and then pull apart. WHat went wrong?
try adjusting the upper tension
change the needle
if you recieved a instruction manual with the machine, look for the part that tells about what fabrics go with which needles, & the thread should move easily thru the needle eye with out any problem
Apr 12, 2012 | Brother XL-2610
Would like to buy a ballpoint needle for Brother XL-2610 machine. Co you sell them? What size should I get for fine cotton jersey? The manual says to get 75/11-90/14.
For light weight cotton use size 11 even 10, thinner ones, instead for heavier fabric use size 14 that is thicker.
Get an assorted pack of ball pointed needles and test them. The needles below are for your Brother machine.
http://www.sewingmachinesplus.com/schmetz-ballpoint-asst.php
http://www.sewingmachinesplus.com/schmetz-ballpoint-size14.php
Jan 13, 2010 | Brother XL-2610
I have a Brother LX3125 14-Stitch Sewing Machine and I am having problems with both the tension on the top thread and bottom thread. Ive tried adjusting it and it hasnt helped. What else could be wrong?...
Take it back to the dealer you bought it from. But you can try changing the needle, make sure the bobbins thread is unwinding the right way, what thread are using, cotton, polyester, etc. Try changing material, needle, does it do it on Streight stitch and zigzag. Let me know about these questions.
Jan 20, 2018 | Brother XL-2600I
Brother XL-2610 Logo
157 people viewed this question
Top Brother Sewing Machines Experts
Irene Tulloch
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
