Here's your
manual. Check Pg. 9 for correct Sub Woofer connection. Leave the
SW=YES setting as is if you any small speakers in the system. It can be set to
SW=PLUS if you want
all bass signals sent to the Sub Woofer. It should only be set to
SW=NO if no Sub Woofer is connected. Experiment between the YES and PLUS settings and leave it where it sounds best to you.
If this was helpful, please rate it "4 thumbs up" - thanks & good luck!
I have the manual and did not see it. I know that you need the GUI to adjust speaker distance. I will try connecting using GUI. Do you know what page in the manual it lists that instuction?
the sub woofer dont play up
