Doesn't work, my friend. In step 7, pressing the ENTER button generates the actual number of images used on the transfer belt. No mention of a percentage and no RESET option.
Drat! Lots of solutions on the Internet. Trouble is, they all work no better than yours.
You can check the level of each item.
1. In ready mode press the Menu button on the control panel everal times until you see 'Setup 'on the bottom line
of the display.
2 Press the Enter button to access the menu.
3 Press the scroll button until 'Maintenance ' displays on the bottom line.
4 Press the Enter button
5 When 'Check Others ' displays on the bottom line,,press the Enter button .
6 Press the scroll button until the item you want to check displays on the bottom line.
7 Press the Enter button The display shows the percentage of item.
8. Press the scroll button display either 'Image Count' or 'Reset'
9a. Choose 'Reset' and press enter to reset the counter after replacing a consumable item
or
9b Choose Image count to display the counter.
10. Press the Upper Level button to return to step 7 and select a different choice or press it a second time to return to step
6 and choose a different item.
11. To return to the Ready condition press the Upper Level button several times until 'Ready' appears in the display.
