Question about Lenoxx Electronics Audio Players & Recorders
Hi i need an instruction manual for the lenoxx ICR 812 B. These are speakers for an ipod but i have lost the manual and just can figure out how to change the time or set the alarm??????
Posted by jackihill3 on
5 Related Answers
Anonymous
SOURCE: setting instruction for Accurist world time wrist watch
Same just happened to me, performthe following:
The analogue hands are not precisely synchronised with
the digital time?
1. Press the lower right button to move the mode indicator
hand to CHR.
2. Pull the lower right button out one click. The hour, minute
and UTC hands will retract towards the straight up 12 O’clock
position. You will see UTC on the top half of the digital display.
3. Press the upper right button to advance the hands to the
straight up 24-hour position. Use the lower left button to go in
reverse.
4. Press the upper left button. You will see HR on the top half
of the digital display. Press the upper right button to advance
the hour and 24-hour hand clockwise until they both point
straight up at the 24-hour position. Use the lower left button to
move the hand anti-clockwise.
5. Press the upper left button. You will see MIN on the top half
the minute hand clockwise or the lower left button to move
anti-clockwise until it is pointing straight up at the 12 O’clock
position.
6. Push the lower right button back in one click.
The watch malfunctions in some way and the above
procedures do not work.
1. Press the lower right button until the mode indicator hand
points to TME.
2. Pull the lower right button out one click. Press the other
three buttons down simultaneously for three seconds and
release. You will see 8’s on the digital display.
3. Press the upper left button. You will see UTC on the top half
the hands of the top dial to the straight up 24-hour position.
Use the lower left button to go in reverse.
position.
Posted on Aug 06, 2008
Anonymous
SOURCE: alarm clock and time w/ clok smooth ipod system
According to the instructions that we received with our clock. You should be able to get the Instruction manual from [email protected] It is also supposed to be under the support section of the website www.dpi-global.com but I couldn't find such a link.
However the "Operational Support" insert has the following:
Setting the clock
1. With the unit powered off, press and hold the "Clock/Display/Play/Pause Button" for at least 4 seconds.
2. While holding the "Clock/Display/Play/Pause Button", press the "Hour" and "Minute Buttons" to adjust the hour and minute on the time.
3. When the correct time is selected, release the "Clock/Display/Play/Pause Button" to set the clock
Setting the Alarms
1. With the unit powered off, press and hold the "AL1" or "AL2" Button for at least 4 seconds.
NOTE: An alarm icon will begin to flash on the LCD display.
2. While holding the "AL1" or "AL2" Button, press the "Hour" and "Minute Buttons" to adjust the hour and minute on the alarm time.
3. When the correct time is selected, release the "AL1" or "AL2" Button to set the clock.
4. Press the "AL1" or "AL2" Button consecutively to switch alarm one and alarm two between sounding to a buzzer, the currently set radio station, or a docked iPod.
Posted on Nov 30, 2008
Anonymous
SOURCE: I can not figure out
1. With the dock station off (none of the functions are highlighted) press and holdthe Clock/display and/or Play/Pause button.
2. After holding for up to 5 seconds (still hold) press the hour or minute buttons to adjust th ehour and minute
3. Once you are done, release your the clock/display and/or play/pause button
Posted on Jan 05, 2009
Anonymous
SOURCE: I have the Jensen JiMs-120
Press and hold the SNOOZE/LIGHT button. This will toggle the Alarm On and Off.
Hope this helps.
Posted on Feb 02, 2009
Anonymous
  • 16 Answers
SOURCE: Instructions; TIMEX Alarm Clock Radio w/CD Player & Nature Sounds
Go to timexaudio.com, select SUPPORT, then select PRODUCT MANUALS.
Posted on Feb 22, 2009
How do I obtain in english a user's manual for a hyundai digital recorder icr 703
Hi
It looks as if all the manuals for this recorder - in English - are listed and obtainable from here:-
Manual search engine manualsdrive com
and entering HYUNDAI ICR 703 into the box at the top of the age and clicking next.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Mar 06, 2015 | Audio Players & Recorders
THIS IS THE QUESTION I ASKED:WHERE CAN I GET THE MANUAL FOR THE KMASHI K-MP 812? THE RESPONSE I RECEIVED WAS ABOUT PRINTERS. THIS IS NOT A PRINER OR COPIER. IT'S A PORTABLE USB DEVICE CHARGER - LIKE F
This is all you need to know:
1. The larger of the two slots on the portable battery is a regular USB slot. You connect the USB charging cable of the device you want to charge (cellphone, tablet, iPhone, iPad, iPod) to it so the device can be charged on the go.
2. The smaller slot is a micro USB port that is used for charging the portable charger itself using the micro USB cable that came with the KMASHI K-MP 812. You charge it by connecting to a regular USB slot on your PC and then take it with you on the road to charge your device.
KMASHI MP 815 2200mAh Lipstick 5V 1Amp Rod Pocket External Extended Backup...
Jan 16, 2015 | Audio Players & Recorders
I have lost he instructions for my Ministry of Sound hi-fi with docking sysytem and don't know how to tune the dab radio...can anyone help?
plug it and with power on but don't turn the station on, leave it in standby mode. then press and hold mem/set on your remote. then set the hour and press mem/set to move onto the minutes. when done press mem/set again and your time is sorted.
May 31, 2009 | Sony STR-D600SS Shelf System
Need an operating manual
I asked my brother and he asked me if any of your friends have got one
If not send me an email at [email protected]
Mar 09, 2009 | Logitech Pure-Fi Dream Speaker Remote...
Instruction manual for innova docking station
They do not exist. I was not given instructions with mine. Now its only function is an Ipod charger and speaker.
Jan 30, 2009 | Innovative iPod Clock Radio with Dock...
Casette belt?
They have declared bankruptcy... My husband lost his job there... Your best bet is to make a big stink with walmart...
Dec 19, 2007 | Lenoxx Electronics CD-102 Cassette/CD...
298 people viewed this question
Top Lenoxx Electronics Audio Players & Recorders Experts
 Grubhead
Grubhead
matt
matt
Are you a Lenoxx Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
