Question about Olympus Camedia C-60 Zoom Digital Camera
OLYMPUS C-60 Camera HAVE THIS PROBLEM HAS MEMORY Karts BIDET closing the cover does not work? D : 1E11 1E011 1E1A
6ya staff
SOURCE:
silly girl
yoav kleinfeld
  • 513 Answers
SOURCE: "Card-cover open" error message
It's when putting the card in.. typically you put it in and it clicks (so to speak).. if you delay removing your finger-push, it does something to the card and makes a Disconnect, although in looking at it, it looks just fine.. and the cover closes... A lot of people are reporting 'door open' errors. The micro-switch in the door housing is quite sensitive and pressure shifts from your hand on the door can cause it to trigger as if the door were opened. some get progressively worse. One fix is to add a little bit of length to the plastic that contacts the switch, either a layer of tape or a drop of epoxy, etc. This may help (or may not if the switch itself is flaky). Another fix discussed bypassing the switch altogether, obviously not for the faint of heart (or cameras in warrantee).
Posted on May 08, 2006
Anonymous
SOURCE: code on display screen D:
same here, with my Camedia C-60 Zoom Apparently the motor has some problems. Did you take the camera to the beach? It must have caught sand or other kind of dirt in the lens mechanism. These digital cameras all have a fixed solution if they fail to work: they are meant to be thrown away. The people at Olympus also have mortgages going, don't they? Half a year ago it was already impossible to get parts for this camera, also, the memory sticks are not around any more, M-XD cards won't work with it, so, yeah, let's come to the Conclusion: this is intelligent (it can write out parts of machine code) landfill. Cheers, Reinhard
Posted on Jun 27, 2007
Anonymous
  • 89 Answers
SOURCE: With the Olympus C 60
Hi!
The Olympus C-60 can support 16 to 512MB of xd Picture card.
I hope that helps.
Good luck and have a nice day!
Posted on Nov 28, 2008
Anonymous
  • 919 Answers
SOURCE: card cover open
The problem you are describing is a problem with a sensor that is on the card cover door. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.http://olympusamerica.com/cpg_section/cpg_servicerepair.aspOlympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $124 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Posted on Jun 11, 2009
lock123
Andrea Lock
  • 6831 Answers
SOURCE: camera will not close error 1e1a
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Oct 07, 2010
Turns off when cover is closed
First don't spent too much mont for repairs, because cameras are becoming cheaper and cheaper and in the mean while better and better.
You could try to open and close the cover several times and hope it starts working as it should. It has a switch connected to it, so the camera can see if the cover is open or closed. Now it is giving the wrong information. If the camera comes on, when the cover is open, that indicates the battery is still good, unless the it stops working within a short period of time.
Jan 27, 2014 | Olympus Stylus Tough 3000 Camera Digital...
Dont know which memory card my olympus c-2 zoom camera takes?
I am not sure about the model number you have mentioned, Visit olympus site to see the compatibility of memory card. You can also visit this link to see the camera xD picture card compatibility for C-series.
Good luck & have a nice day
Rating the solution is highly appreciated.
Sep 04, 2010 | Olympus Camedia C-60 Zoom Digital Camera
Card cover open fe 280
You can fix it with a small piece of tape inside the unit where the memory card goes. Just look inside for a sensor or a small button, and try pressing it down yourself. If that works, then maybe a slip of tape over that spot would fool the camera into thinking the cover is closed. If this is not fixing your problem take your camera to Olympus as this problem involves some built in mechanism troubleshooting.
Thank you !!
Jun 18, 2010 | Olympus FE-280 Digital Camera
Camera part won't power on
I had the exact same issue with the D-395.
I wiped off the battery contacts and the ends of a newly charged set of batteries to make sure they were clean. Also while the batteries were out, I opened and closed the lens barrier or sliding cover to try and drain any juice still in the camera. I put the batteries back in and slowly/gently slid open the lens cover. It turned on and works fine now.
Nov 08, 2009 | Olympus Camedia D-395 Digital Camera
Card cover open error message
Hi!
You need to make sure that the memory card is correctly installed on the camera and that its door lock is closed.
Sep 05, 2009 | Olympus Stylus Verve / ?-mini Digital...
My camera was dropped, and now the flap that covers the battery and memory card will not close, because the little part that kept it closed is what broke off. Is it possible to get this fixed, and does...
Roughly about $60 and yes it can be repaired use the phone and ring around the camera shops That way you dont have to commit and can select the cheapest option
Aug 17, 2009 | Olympus Stylus 740 Digital Camera
Card cover open
Jun 11, 2009 | Olympus FE-190 Digital Camera
With the Olympus C 60 Zoom what is the most memory I can use on the picture card for this camera?
Hi!
I hope that helps.
Nov 28, 2008 | Olympus Cameras
Card cover open display wont come off the lid is a lil open how can i fix its for an olympus digital camera 6.0 mp
Check you memory card slot cover.. it shuldnt b closed properly...
Close it properly and try it!
Sep 22, 2008 | Cameras
Olympus Camedia C-60 Zoom Digital Camera Logo
106 people viewed this question
Top Olympus Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you an Olympus Camera Expert? Answer questions, earn points and help others
