Question about Microsoft Xbox 360 Console
I have a red light on the fourth player spot - Microsoft Xbox 360 Console
Posted by freshfadedav on
Anonymous
  • 3 Answers
Remove all the cables (composite/component, power, you know, anything that plugs into the console) and let it sit for a minute or so. Plug everything back in. If it still doesn't work, remove the hard drive and attempt to start the xbox. If it works, the problem is with your hard drive. If it doesn't work, the problem is with the xbox itself. Regardless, you'll have to contact xbox customer support to fix either of these problems.
Posted on Aug 23, 2011
Wiring diagram
and the mystery vehicle is?
Oct 15, 2017 | Cars & Trucks
I lost my remote and bought a innovange jumbo remote but cant figure out to program the remote to the dvd player. can you help?
First, make sure the device you want to connect with your remote is turned on, whether that's the television `, DVD player, VCR player, etc. Now aim the Innovage remote at the device. Press the button on the remote control that corresponds to the device (TV,DVD etc.). Now, press and hold the SET button on the remote control until the LED light on the remote control holds a steady red.
Enter the 4-digit code for your device by pressing the number keys on the remote control (see list below). When you press the fourth digit, the LED light should turn off. This means the remote and the device are "speaking" to each other. Press the OK button to store the code.
If the LED light blinks three times and then remains a solid red, the Innovage remote doesn't recognize the code for your device. Verify the correct code, then go through the programming steps again.
Test the function by using your remote to cycle through all programmed devices (TV, VCR, etc.).
You can find the codes from below website
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/innovage/jumbo-manual.zip&area=other
Thank you
Oct 18, 2010 | Durabrand DVD-1002 DVD Player
How do i get my red eye fixed
First make sure how many lights are red, red ring of death with light up the player 1,3,and 4 slots. If all 4 are glowing try an av cable (sometimes rrd will look like all 4 are lit but look carefully and often the fourth slot is only reflected light). next log onto http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair and enter your console information. If the rrd warranty is still active, they will repair it for free (rrd is warranteed far beyond the normal console warranty, so be sure to try this before opening your console).
Mar 01, 2010 | Microsoft Xbox 360 Console
I have an xbox360 and it has a red light in the fourth player slot
E68 error message? If so, turn off system, take off hard drive, put hard drive back on, turn system back on.
Feb 19, 2010 | Microsoft Xbox 360 Pro System Console
One red light
this is a video error. Your creen should say E74. I can't stress this enough you shold do the x-clamp fix
Jul 11, 2009 | Microsoft Xbox 360 Console
Cassette player hook up
The answers are on this website....
CLICK HERE
Dec 01, 2008 | Dell Dimension 3000 PC Desktop
Temp won't go down to target
Sounds like your unit is low on refrigerant gas.  Too little gas causes rapid boiling of refrigerant and makes the cold spots.  You'll need professional help.
Sep 09, 2008 | EuroCave Comfort 260 Collector's Package...
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Daniel Dollive
Daniel Dollive
Raj Patel
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
