Question about NetGear N600 Wireless Dual Band Router
I bought Netgear Wireless N150 Modem Router from UK. I can't use this Router is Saudi Arabia ??? the internet provider is STC . I have been told that STC has block all netgear routers or something to do with configuration. I also been told that I can download an application in to my laptop to solve this problem . could u help? Thanks
Posted by ahmed_alquds on
5 Related Answers
Anonymous
SOURCE: Not able connect to VPN from my new Netgear WGT624v3
Uncheck the "disable SPI firewall" option in the wireless settings for the router.
Posted on Nov 22, 2007
Anonymous
  • 51 Answers
SOURCE: Netgear Router WGR614 will not connect to internet
Looks like when you reset the router you have lost all yur configuration and back to the default factory settings.
Bridge the 5100 first.
1. In your web browser browse to »192.168.0.1 This address will be located on a yellow sticker on the bottom of your modem.
2. The first screen will ask you for your Modem Access Code. This also will be located on the same yellow sticker.
3. Select Advanced from the blue buttons on the left.
4. Click the PPP locations button.
5. The modem may ask your for the Modem Access Code again. If so type it in again and click continue.
6. Select the radio button labeled, "Bridged Mode (PPPoE is not used)"
7. Click Save Changes.
8. A "PPP Location Warning" page will come up. Click "Change PPP Location."
9. A "Restart Needed" page will come up. Click "Restart"
10. Reboot your computer and and then connect the router
11.Configure the router for PPPoE using your ISP uid/pass
12.Configure your wireless using WEP
13.Desktop : Using Dell wireless client configure the client using the same SSID ,wep as configured in the router
Laptop : follow the same as desktop
(by default dell wirelesss client takes over the wireless configuration in dell pc.to disable it and use windows wireless client..control panel ->administrative tools -> services -> enabl2 wireless zero configuration)
14.after all configuration shut the desktop,laptop,router,mdm and pwr them in seg..first modem and then router and then your desktop or laptop
Cheers !!!
Posted on Feb 26, 2008
Anonymous
  • 141 Answers
SOURCE: how to add a netgear wgr614 router to dsl modem
The NETGEAR router needs to be configured. Call NETGEAR. Try this also http://technicalsupport.blog.friendster.com
Posted on Feb 16, 2009
garethmt
Gareth Tomlinson
  • 116 Answers
SOURCE: I have two routers Netgear DG834Gv3 and Thomson
sorry, can't be done. the key word here is "router".
Posted on Nov 13, 2009
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: PS3 and Netgear WGR614 V7 Router
Basically the PS3 wireless settings needs to be configures with the Netgear wireless router settings.
To test if the modem is connects to the Internet, connect a computer into the modem, if it works then the modem is configured correctly. If it doesn't work, then contact your ISP and get them to test your modem connection.
For details on how to configure the PS3 click on the WEB link :-
wii
.php">http://fixhomenetwork.com/xbox-play-station-wii.php
Posted on Dec 20, 2009
In my lap with windows 8 version netconnection i s not available,but with same wifi modem..NETGEAR N150 WIRELESS D S L Modem Router mobile is net.connected.
Netgear are products that are last to just about 90 days. I am a computer tech and do a lot of house and business calls to TS networks. Most problems come from Netgear, once they switch to another brand, the problem disappear. Even I had a wireless Netgear router, and had to return it because the life span was about 4 month and the complimentary support is only 90 days.
Just by rebooting the modem (turning it off and on) usually fix it for about 8 hours, then the cycle start again. After rebooting the modem/router, delete your saved network from Windows 8 and start fresh. That should work.
Mar 21, 2015 | NetGear N150 Wireless-N ADSL2 Modem Router...
NETGEAR N150 WIRELESS ROUTER STATIS IP ADDRESS CONFLICT WITH DSL 502T MODEM
Change the ip address of the router to 192.168.5.1 and power cycle.
Dec 21, 2012 | Computers & Internet
I bought a NETGEAR N150 Wireless USB Adapter WNA 1100 last week from Currys, I eventually managed to install it! Unfortunately I cannot get any instructions on-line so I cannot use it!! Can you tell me...
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
Aug 31, 2011 | Computers & Internet
I have a motorola 2210 modem and want to switch to a Netgear N150 wireless modem router dgn1000. I unplugged the Motorola modem and connected the Netgear but it does not work? I typed in 192.168.0.1 to...
Yes you need to setup the modem to bridge mode.
below is a guide you can follow on how to setup the motorola to bridge mode.
http://www.dslreports.com/faq/15855
Feb 27, 2011 | Computers & Internet
Does the netgear n150 wireless router work with the westell 6100G single-port modem provided by verizon? they **** btw.
Yes this router will work with any DSL or cable modem that is out in the market right now, it just need to be setup properly to work with your modem.
Feb 09, 2011 | NetGear N150 / RANGEMAX 150 Router
Qucknet stc modem from Saudi Arabia model TCT mobile CE0700 can it be unlocked Pls help details TCT mobile ltd Model HSDPA Rev T11A1000xx IME13562370303176653
Your cell phone may be locked to a particular cell phoneprovider and in this case it needs to be unlocked to use with a different cellphone service provider. To get the security code/restriction code to unlock thecell phone from the current cell phone provider so you can use the SIM cardwith a different phone provider, Please click on this link and follow myinstructions :- http://www.fixya.com/support/r4049238-unlock_cell_phone If your phone provider does not help you then this WEB siteit provides security codes for a small price. http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHw Try this WEB site also - UnlockFree http://www.unlock-free.com
Dec 31, 2010 | Computers & Internet
Linksys WAG200G
OK the main problem right now that the only data carrier in Saudi Arabia (STC) is upgrading its infrastructure to provide high bandwidth to end users. STC is using Huawei MSAN which doesn't support linksys.
Here is a firmware update which they say it will overcome some of your problems.
Mirror1
Mirror2 - rapidshare.com
Mirror3 - Google Groups
here is the link for the original article in Arabic
Feb 12, 2009 | Linksys WAG200G Router
Setting up a wifi router
Configure the router first using the desktop. Make sure the modem is connected to the Internet port of the router and the desktop to port 1. Just run the setup CD that came with the router and it will guide you through the setup process. You can also try to reset the router first by pressing the reset button at the back for 10 seconds then unplug the power to the router and the modem, wait for 30 seconds. Power on the modem first and wait for the lights to stop blinking, then the router. check if the internet works hardwired.
Hope that helps.
If not, tell us more. Who is your ISP (Internet Serivce Provider)? Is it a cable or DSL?
Jul 24, 2008 | NetGear WGT624 Wireless Router
NetGear N600 Wireless Dual Band Router Logo
67 people viewed this question
Top NetGear Computers & Internet Experts
Mike
efs_perpends
efs_perpends
Lee Hodgson
Lee Hodgson
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
