Question about Zebra TLP 2844-Z Thermal Label Printer
Hi I am printing barcode labels on a Zebra Tlp2844-Z. I can print resident barcodes in passthrough mode using the old Zebra driver (1.0.0.43) but the barcode does not print using the ZDesigner driver (2.6.59). I have enabled Passthrough mode and send the following : ${^FO40,112^BEN,64,Y,N^FD9780643065475^FS}$ in a text box control on an MS Access report. This works on the old driver. Everything works using the new Driver except the barcode is blank. I have to use the new driver to as it is required for Windows 7. However the new driver it does not work correctly on either Win7 or Win XP when I send passthrough commands. When I print via the old driver everything works. Change to the ZDesigner driver and the barcode is blank. So everything is exactly the same - printer, code, operating system. Only the driver is changed Any ideas why this might be happening? Thanks
Posted by martin100 on
Label Queen
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 51 Answers
Have you tried creating the barcode / label using the ZDesigner software? It is available free on their website and I'm sure you'll find it easy to use. Hope this helps!
Posted on Aug 30, 2011
Barcode Print aliginment is not proper in windows7
Try a different print driver. Go to Zebra web site and download driver for Windows 7'
Apr 22, 2014 | Zebra Office Equipment & Supplies
We can't get our Zebra TLP2844 to print on the left matgin. It only prints in the middle of the label, which messes up the barcode. Our IT Dept has the manual and they can't seem to fix it. It was working...
reset the printer to factory defult ( from the driver( download segull driver) www.seagullscientific.com
check if the driver that you using have the correct Length and the With from the labels that you use.
Print a test page (should come with windows logo plus the text in all label. clean the printhead.
Aug 18, 2010 | Zebra LP 2844 Thermal Printer
Zebra 105SE printer will print text and images just fine, but will not print bar codes from any software including Bartender or TechnoRiverStudio. If i export the label as an image I can print it just...
Bartender is a pretty good label software package - strange that you're having problems with a barcode. Are you by any chance trying to print a 2D barcode such as Datamatrix ? If that's true, then the problem is that the datamatrix barcode is not a resident barcode in the firmware version of that printer which is an older model. There should be a choice in bartender, in the properties of the barcode field that allows you to send the barcode as an image or graphic. The barcode will then print.
If you're trying to print a linear barcode (C39 or C128 or UPC for example) and it they won't print with the steps you have taken, then something is definetly wrong. Another option would be to take your label format and print-to-file instead of print-to-printer. There should be an option on the print screen for this. By then opening the file, the ZPL (Zebra's programming language) can then be examined to see exactly what is being sent to the printer.
Hope this helps !
Apr 17, 2010 | Zebra 105Se Thermal Printer
Hi, I am having Zebra TLP 2844 barcode printer.I have installed the printer in my machine. I have tried to take barcode labels.From application, for each and every label i need to generate the label in PDF...
The TLP2844 can print from any windows application providing the application can use a windows printer driver.
The page size oof the .pdf needs to be the same size as the physical label size.
Nov 03, 2009 | Zebra TLP 2844-Z Thermal Label Printer
TLP2844 won't print
Hi David,
Default the printer so you have a green light.
Print a configuration label so you have the printer's settings.
Check the document you are trying to print.
If your "normal document" is using PCL, it won't print because you aren't speaking the printer's language.
Make sure you are using a Zebra driver and that the label/media settings match your printer. Look at your direct thermal/thermal transfer setting and your media length setting -- especially continuous vs. non-continuous.
Sep 21, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra driver for mac
OS X 10.5.2 and above have built-in ZPL and EPL drivers. Plug the printer in to USB, go to System Preferences > Print & Fax, click + , and choose the Zebra driver. For the LP2844 you choose the EPL2 driver.
Jul 07, 2008 | Zebra Eltron TLP 2844 Thermal Label...
Zebra TLP2844 does not print the barcode label
Can you print the barcode using the software that come with the printer. Zebra TLP2844 come with basic Designer software. Test whether it's printing the barcode or not.
IF it prints the barcode via its software, then you might be having barcode font problem between your application/os and the printer.
May 21, 2008 | Zebra Eltron TLP 2844 Thermal Label...
TLP 2844 won't print barcodes
The printer is in line mode. Do the following to take it out of line mode:
Turn printer power off.
Hold the feed button while turning printer power on.
When the light starts flashing, release the feed button.
When the light starts flashing again, press and hold the feed button.
When the light turns steady amber, release the feed button.
When the light turns steady green, the mode is changed.
Verify the mode by printing and inspecting a status report.
This requires good timing and may take several tries. You'll know it worked if no labels are reeled out after you're done.
Apr 10, 2008 | Zebra LP 2844 Thermal Printer
Zebra TLP 2844 Controlling the font size w/iSeries??
Hi Burgymon,
The font that is used under the barcode will use the last font properties described prior to the barcode in the output. You may want to suppress the human readable option and create a separate text field to display the text version of the barcode contents.
Mar 25, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2844-Z Thermal Label Printer Logo
938 people viewed this question
Top Zebra Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marvin
Marvin
Ekse
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
