Well its obvious that if its not loading then the image on the hard drive is bad. If it has a cdrom borrow the same OS cd from a friend use your key. If not you will need an external cdrom and tell the bios to boot from external devices again using a friends cd. You can as well have this done at a shop most have all OS versions there already--Good luck...
The Sylvania Netbook SYNET7WID-Z does not have a Hard drive. It is simply a motherboard and nothing more. There is also no Cd Rom. and in the case of having the BIOS boot to CD, You CANNOT there is no other screen while starting other than loading OS. When i figure this out i will post the solution.
There is noway to flash the contents of a bios chip to an external data device. Kinda one way street. You can have the flash chip rewrote but from Ive expierenced if they are losing there load the chip is bad. They can be replaced
