SOURCE: Cd player
M-Error is a mechanical error and could have a multitude of causes. just went through it with a TAD-5160 unit where it was a small slip gear moving a tin lever to ingage the transport sled to insert or eject the disk from and to the carusel. You may have to take the unit apart and asess the problem. Harleysp.
SOURCE: Problem with JVC stereo shelf system
It could be many things but if you put the disc in and you can hear the noise it makes while its scanning the disc then its probably the laser is mis-aligned. If you cannot hear any noise at all and it comes up with error after a while then it could be the entire laser unit needs replacing. Good luck.
SOURCE: my jvc 5 disc player
It is possible that the loading belt needs to be replaced, or the timing gears are out of sink, either way it must be taken apart to find the problem, sometimes I find the gears ware out causing the unit to lock up. When you hit the eject button do you hear a motor running? that should be the sound of the loading mechanism trying to eject the tray.
