Question about Pool & Spa
In econ mode my 1998 spaform hot tub does not appear to heat but it is ok in standard mode.
Posted by hollywoodhat on
US Parts Center
  • 719 Answers
In the economy mode it will only maintain a temperature so that it will not freeze. Economy mode is mostly for vacation time or for winter if you are not going to be using the hot tub for an extended period of time.
Put it into the standard mode and you will be able to have a HOT tub and will function as it should
US Parts Center
Posted on Aug 23, 2011
Dawn Firth
My spa form odyssey hot tub is flashing the code b y and will not heat up what does this mean?
Posted on Dec 27, 2020
My Dream maker Odyssey spa is stuck on economy mode. There is no way for me to see to change it to standard mode.
Try pressing 'TEMP' then 'LIGHT'. You may have to do this a couple of times.
If you don't have a 'TEMP' button, either the temperature up or down will also work.
There are three modes, ECONOMY (EC / ECO / ECON), SLEEP (SL / SLP) and STANDARD (ST / STD). For everyday use keep it on STANDARD mode.
Cheers,
Ian Kime
Ian Kime Hot Tub Sales Repairs and Servicing
May 02, 2017 | Standard Pool & Spa
I have a spaform hot tub which is flasing Lf Ecny what does this mean
the fault is "low flow" and its in economy mode , this is a minimal mode that is without heat , just recirculates water to prevent a freeze up
you'll need to investigate the cause of low flow alarm , start with the filter , clean/replace it
Dec 22, 2014 | Pool & Spa
Spaform hot tub manual
check the timer or may need to reset the cycle on it..(reprogram the controller)
Jan 09, 2014 | Pool & Spa
Not sure how to get balboa hotub off of Econ mode and to get it to heat up
use the Mode button and either the temp up or temp down button to change the setting on your tub from econ to std.
Rod
US Parts Center
888-521-6183
Feb 03, 2013 | Pool & Spa
Need user manual for spaform hot tub prestige 50
I looking for user manual for spaform Grand Canyon any ideas
Aug 01, 2012 | Vehicle Parts & Accessories
My readout says econ and is not so warm have my kids wrecked it
ECON is a different mode of operation. In this mode it only looks at the temperature of the spa once a day. You need to look at your manual and use the topside control to change from ECON to NORMAL operation.
Sep 11, 2010 | Qca Spas Paradise Hot Tub
Qca Spa pumps and blower will not come on, water down to 35º f
Ken,
You need to contact a hot tub technician/engineer as you clearly have issues.
'ICE' means that the water temperature is too low and therefore the pumps will be turned on to prevent freezing within the plumbing. Depending upon the spec and settings, the heater maybe disabled during 'ICE' condition.
'ECON' is Economy Mode. If you have a mode button, keep pressing it until you see 'Stan' on the display. This will put the system back into the standard mode.
'FLO' means that there's insufficient flow of water through the heater, or non at all. 1) Check the water level - top up if low. 2) Ensure that all jets are open and flow water - if they don't you may have a pump issue. 3) Remove the filter(s) and see whether or not this clears the fault, if so clean or replace the filters.
'COOL' is displaying because the set temperature is much higher than the current water temperature.
As I mentioned at the start, you really should get someone to take a look at your hot tub. You may have a few issues that need resolving.
Regards,
Ian.
http://hottub.synthasite.com
Feb 07, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
I have a paradise spa the readout keeps saying econ what does this mean also Im having a hard time getting it to stay at 104 degrees
The econ sounds like a maintance mode that is to say economey mode. You probally have a simple way to set this back to a use mode but you will need to look this up in your book or find someone fimaller with this spa. Most books can be found on line if you look it up by brand and model number. Good luck.
Dec 14, 2009 | Qca Spas Paradise Hot Tub
Pool & Spa Logo
637 people viewed this question
Top Pool & Spa Experts
john h
David Spradling
David Spradling
rogerpaul3
Level 1 Expert
Are you a Pool and Spa Expert? Answer questions, earn points and help others
