Question about Locks & Locksmithing
Chamberlain whisper drive garage door keypad
The garage door keypad was working very well two days ago. Now, when we put in the 4-digit code the lights on the keypad just blink on and off and the door does not open.
Please let me know what I need to do, I am desperate to have it fixed since I would have been locked out of the house many times without it.
Thanks Lucy R
Posted by resa333 on
Lee Most
    New Friend:
  • 14 Answers
It might be your batteries are dying, or that someone has been tampering with it and messed up the combination. You can get the manual if you don't have it anymore by searching Google for "chamberlain whisper drive garage door opener change code". Page through the instructions and reset the motor control to erase all your remotes, put new batteries in the one on your wall and the one in your car if it's not the kind that's built into the car, and then follow the instructions to program new codes.
Posted on Oct 23, 2017
5 Related Answers
Anonymous
SOURCE: Chamberlain Whisper Belt Drive
door does not close without holding wall button in
Posted on Nov 21, 2008
Anonymous
  • 244 Answers
SOURCE: Chamberlain garage door opener won't close
read manual, if you have, on trolley engagement
Posted on Jan 17, 2009
Anonymous
  • 10 Answers
SOURCE: my garage door will only open 1/4 if the way
get a new door
Posted on Jan 21, 2009
glenmann62
Glenn Mayer
  • 91 Answers
SOURCE: Chamberlain garage door opener unit-is it compatible with craftsman keypad?
Hello,Linda well this is your lucky day ,I have installed garage door openers for sears for 10 years and i can tell you that craftsman,chamberlain ,and liftmaster are all the same machine and manufactured under the liftmaster name , if you buy it from home depot it will be a chamberlain ,if you buy it at sears ,it will be a craftsman, and if you go to commercial building supplier it will be a liftmaster! now getting that out of the way even though they are all compatible ,there is one thing that stands in their way and that,s time ,For example if your chamberlain machine is 5 years old and you went to sears last week ,the chances of the frequency being the same are not good , most likely you have the wireless keypad , one way to test the sears keypad against the chamberlain machine is to locate the smart button on your machine ,this button allows for programming of remotes and keypads , to test and see exactly what im talking about take your remote and locate the smart button ,if you have three buttons on the remote press one of the buttons that are not being used on the remote ,above the smart button their will be a blinking light ,if you press your remote button you will notice the light go from a blink to a rapid flash , This is telling you that you are sending a signal for programming to the machine , well the keypad is exactly the same all you have to do is push the enter button on the keypad and have someone watch for the rapid blinking light ,if they are compatible the light will blink rapidly on the machine so all you have to do now is have someone press the smart button once on the machine your indicator light will now be a solid light you will have approx 60 seconds then to put a 4 digit code in the keypad and then press and hold down the enter button on the keypad , at this point you will notice the lightbulbs on the chamberlain machine to shut off and come back on this is to tell you that the machine accepted the code , after thats been done you can use your keypad , you can also find the owners manual to the chamberlain and follow the same instructions to programming the remote , they are identical in programing , if your keypad is not the same frequency you can also tell by looking at the frequency code on the backside of the keypad and also the chamberlain unit usually where the light bulb is will be its code
Posted on Mar 04, 2009
efs_perpends
efs_perpends
  • 1997 Answers
SOURCE: I need a manual for a Craftsman Garage door opened
Try at www.managemyhome.com
That's Sears support site for craftsman manuals, parts, etc.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 02, 2009
Why won't the keypad outside mount not open the garage door but the remotes work fine.
U will have to re program the keypad follow the directions on the lid of the keypad now on some models u have to hold down * # at the same time until it stops blinking then enter your 4 digit code press enter hold for 2 sec if opener does not release and press again as soon as u hear the opener click or light blink press 0 to store code then wait 60sec and try
Sep 02, 2014 | Chamberlain 1/2-HP Whisper Drive Belt...
I have a Model 139.53684 keyless enty need to reprogam code - have a Chamberlain Whisper Drive Operator. Can you give me insturctions
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Mar 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
How do i change the code on my keypad outside the garage door on my chamberlain whisper drive? someone stole the sticker from the pad... thanks
Nov 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
I need to change the key pad to my chamberlain whisper drive garage door opener. Recently got divorced and ex has the origional key pad entry number. I can not find anywhere that knows how to change it....
Press the colored learn button on the motor head until the led light by it goes out. This erases all old codes out. Make sure you have all the remotes handy too. -----Press and release the learn button and then press the button on the remote. For multiple remotes repeat from -----. For a keypad press and release the learn button and then within 30 seconds enter in the 4 digit code(different than the old one) and enter. This should do it. Thanks BB
Aug 29, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
We have installed a chamberlain wireless keyless entry. The problem is that when our neighbors house uses their keyless entry our garage door opens without us using our code. We have checked this seveal...
We have a Chamberlain Whisper Drive Plus. The keyless entry stopped working, suddenly. I have changed the battery, not the problem. I cannot get it to work, and cannot get it to reprogram. The keypad lights up when buttons are pressed, but when I press "Enter" the whole keypad flashes for about 30 seconds and then just goes dark.
May 10, 2010 | Universal Garage Wireless Keyless Entry...
Chamberlain GDO light turns on randomly at any time of day or night. (Whisper Drive with Motion-Detecting Control Panel 935CB.)
If you don't have any puppies or strange animals running around your garage I would disconnect the wall control for a couple days. If your problem stops I would suspect that control. If you have a heated garage I would also make sure there is nothing that could be moving from the air movement from the furnace.
Apr 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
Just bought a new PD210DM opener but still have
I don't know this model. (in australia). the chamberlains here are probably the same. the 4 digit code you first put in the keypad is what you have to use. push the learn button on your operator then punch in your 4 digit No. Hold the enter button on your keypad until the light flashes on the operator.
That should code it in.
freddy51
Feb 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
Trying to program a keyless pad for a chamberlain door opener
pressing all buttons firmly....
1) on the keypad, enter your 4 digit code, press enter once
2) on the operator head, press the learn code button once
3) (within 30 seconds) on keypad- enter 4 digit code again, press (slowly) enter, enter, enter
the opener should be programmed
Aug 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Locks & Locksmithing Logo
720 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Chris Walker
Chris Walker
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
