Thirst thing to try is take the batterys out of the remote and push all of the buttons to get any electric static for say 3 to 5 minutes if that don't work try to see if your remote signal works by using your iphone and take a few photos of the remote beam when pressing ,or the remote in the tv might have gone. Ps happened to me
It sounds that, the memory IC to your TV has damaged. This IC can be located very near to main system control IC. A very small one, with 8 solder terminals. Even though it is very small, function of it while the TV works is great. The work is a semi-skilled one, and you must have some knowledge in electronics to proceed.
There is a way to tell if you have a bad board, or a bad panel.
1. Make the room dark and turn on the TV. Can you see it light up? If so, does it stay lit or turn right back off?
2. If the panel lights, but you have no picture, I would suspect the T-con. Some units now have the T-con incorporated with the main board, so you will need to check.
3. If you never get any light at all, then I would suspect the power supply.
4. If you only get light for a second or two, then you have a bad panel.
Sounds like the lamp is burned out.If you are handy with a screwdriver, you can replace yourself. best price i found on mine was at dlplampxpress.com, rens about $160. hope this helps
