Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
Need instructions on how to replace Moen 2700 valve cartrigde.
Posted by s_encinia on
Paul Beyer
  • 528 Answers
How to remove moen bath faucet handle that has no set screws and is all 1 piece
1.) its not all one piece
2.) the tower threads onto the valve body, you may need to loosen the mounting nut under the sink top with a basin wrench to relieve the pressure on the handle tower
3.) this is the exploded parts view for your faucet: http://www.moen.com/shared/docs/exploded-parts-views/s498pt.pdf
4.) this is the instruction sheet for your faucet, including a technical support number you can call: http://www.moen.com/shared/docs/instruction-sheets/ins1207.pdf
Aug 26, 2014 | Moen Showhouse S498 Savvy Two Handle...
I can't get to the cartridge inside my Moen Aberdeen handle
The detailed exploded view of the parts is in this sheet.
Hope this is the right model that you have.
http://www.moen.com/shared/docs/exploded-parts-views/7590cpt.pdf
you will need to undo the nut holding the cartrigde in place. Sometimes you will have to get a special tool to undo these parts.
Apr 19, 2014 | Plumbing
How do i stop a moen 4570 from leaking
all moen faucets use a replacement cartridge type packing box, and have a liftime warranty. find a local plumbing supply that sells moen and they should help you get the right cartridge. (it will come with instructions.. there is NOTHING you can do so stop it temporarily, unless you shut off the valves feeding the faucet.
Sep 01, 2012 | Moen Plumbing
I need a piping diagram for a Moen s3371 and a s3600 valve
http://www.moen.com/shared/docs/product-specifications/s3600sp.pdf
http://www.moen.com/shared/docs/instruction-sheets/ins1281c.pdf
http://www.moen.com/shared/docs/exploded-parts-views/s3600pt.pdf
http://www.moen.com/shared/docs/exploded-parts-views/s3371pt.pdf
If you did your rough in for the hot water coming up from the left of the valve as you face the control and the cold on the right, that is traditionally correct.
Jan 15, 2012 | Moen Plumbing
We have a 20 year old tub shower single valve. We replaced the brass cartridge with a plastic cartridge and water is leaking out of the front when the water is on. Do we need to replace it with a brass...
I'm not now nor have I ever been a fan of the plastic moen replacement cartrideges. I don't know if they still do but probably about twenty five years ago I tried using a few of the plastic replacements,mostly due to high cost of the brass moen factory ones I think every one leaked. Then I actually read on the instructions that it was not unusual for them to leak some. My suggestion is to get a good brass moen magnum cartridge and be done with it for another twenty years. Hope this helps you. Thanks.
Nov 17, 2010 | Moen & Replacement Cartridge
We have a Moen shower valve in our motor home and we are not getting any hot water. It has worked fine for the sence it was new. It;s a 2007
Assuming that you have hot water everywhere else my thoughts are that you have a small bit of rust,sediment or other foreign matter in the control cartridge. It's possible that the scald guard feature of the faucet has slipped so it's not allowing hot water to get thru. Either way if you purchased this new moen will provide replacement parts free.If you are mechanically inclined you can perform these repairs yourself and save significantly.Last time I checked the cartridge,scald guard balancing valve are all one part and cost about ninty bucks. Prepare to be patient and call 1-800-BUY-MOEN. You will need the model number,approx. age and explanation of your problem.Good luck. Hope this is of some help to you. Thanks.P:S they will generally provide installation,adjustment instructions and trouble shooting tips if you ask.
Nov 05, 2010 | Moen 3175 Legend One Handle Shower Faucet...
How do I get to the valve cartridge to replace it?
how to replace moen cartridge for two handle kitchen faucet ... cartridge for two handle kitchen faucet exporters,how to replace moen cartridge for two handle kitchen faucet suppliers,how to replace moen cartridge ...cn-faucet.com/ kp-how-to-replace-moen-cartridge-for-two-handle...
Mar 17, 2010 | Moen Bathroom Sink Faucet - 4-inch...
Moen one handle tub & shower is leaking from spigit
A stem is a cartridge in a real old valve. You have pulled retainer clip, you can try to pull it out with pliers, but you might need a moen cartrigde puller.
Sep 06, 2009 | Moen & One Handle Tub & Shower Faucet
Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
246 people viewed this question
Top Moen Plumbing Experts
john h
Bruce Robin
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
