Question about Canon imageCLASS D320 Digital Copier
I have an Imageclass D320 printer. After a paper jam, I took the paper out and installed the cartridge back, but the machine keep making a loud noise when I close the right cover and showing "install cartridge" on the screen. I have tried so many time to reinstall the cartridge but the same problems occurred and it won't operate anymore.
Posted by pcs99 on
  • 2 more comments
  • pcs99 Aug 23, 2011
    I did the steps you said but the problems remained unsolved. I had this problem before and I was able to resolve just by re install the cartridge or open and close the right cover to reset it. However, this time on top of the error message, there is a loud noise when I open and close the right cover and the message would not go away --> machine is not working!!
    it did not work. As soon as I plug the power cord on it started to make the loud noise again. I tried to re-install the cartridge, the message still show and it was the same. Any other suggestion? thanks
    They recommended that and I did it, still didn't help. any other solution?
    I don't think it is the cartridge. I checked what you recommended and it didn't help. Even when I plugged the power cord in without the cartridge the machine still make the same noise about 5 seconds. And when I tried to put the cartridge in, it still showed the message. I have tried it a few dozen times.
Avishek Samaddar
  • 639 Answers
This problem is seen in many color printers.
This is really irritating to handle and ultimately yields to carriage head fault.
Thus you need to handle this a bit carefully.
1)Switch off the printer and let it for 5 - 10 mins. 2)Now replace the cartridge with the new yellow cartridge
Now switch on the printer.
If problem persists repeat the steps 3-4 times.
Replace the new toner with old cartridge that the printer can detect and then switch off the printer.
Follow the above mentioned steps again.
Try this for 3-4 times.
Posted on Aug 23, 2011
Jose Cada
  • Canon Master
  • 3,530 Answers
Welcome to Fixya
Try opening the right door and close it again. That is the door that you open when you replace the cartridge. If still will not work, replace the cartridge with a known good cartridge - preferably a new (not refilled or recycled) one.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
  • Jose Cada
    Jose Cada Aug 23, 2011
    check the ground tab. open your printer cartridge and check the right side where is the drum ground position. on top there is a black plastic guide. put it to the right position if it is not in the right place.
Aloke Das
  • 1,833 Answers
For your problem do the following
Turn the copier off; disconnect the USB cable from the rear of the copier. Remove the cartridges from the product.
Wait for the 'Insert Cartridges ' message to display on the control panel.
Disconnect the power cord from the back of the product.
Wait 60 seconds.
Reconnect the power cord. If the product does not automatically turn on, press the Power button. Reinsert the cartridges, and then close any open doors on the product.
Then reconnect the USB cable to the rear of the product, and then try printing again.
Use original cartridge always. Compatible duplicate cartridges can make this hazard.
Reset your printer, remove all pending print job from control panel. It will solve your problem.
ZJ Limited
  • Canon Master
  • 17,970 Answers
Here are the original instructions:
Open the right cover.
Remove the cartridge from the machine.
Remove the new cartridge from its protective bag.
Save the protective bag. You may need it later when you remove the cartridge from the machine.
I have an Imageclass D320 - zjlimited_637.gifuploads/images/zjlimited_637.gif" alt="zjlimited_637.gif" class="h_mi" />
Rock the cartridge 5 or 6 times to distriI have an Imageclass D320 - zjlimited_638.gifenly.
Place the cartridge on a flat and stable surface. Grip the sealing tape tab and snap it in the direction as shown. Make sure tI have an Imageclass D320 - zjlimited_639.giff is detached from the cartridge.
While grasping the cartridge with one hand, firmly and slowly pull the sealing tape tab straight out with the other hand to remove the sealing tape completely. Throw the tape away.
To avoI have an Imageclass D320 - zjlimited_640.gifape, do not pull the tape out at an upward or downward angle.
HoldI have an Imageclass D320 - zjlimited_641.gifd position the arrow mark on the cartridge towards the inside of the machine shown below.
Align the projections (A) on both sides of the cartridge to the guides (B)I have an Imageclass D320 - zjlimited_642.giflocation (1)) and gently slide the cartridge into the machine until the right cover slightly rises up (location (2)).
The right cover moves simultaneously with the action of the cartridge. Do not push the cartridge farther tI have an Imageclass D320 - zjlimited_643.gif Doing so will result in catching your hand in the I have an Imageclass D320 - zjlimited_644.gif>
Close the right cover and the cartridge will be set in place (location (3)).
If the LCD displays [INSTALL CARTRIDGE], reset the machine by opening the right cover and then closing it.
Try a hard reset of the printer then, in case the error message is merely sticking or a remnant of a previous status, that the hard reset might clear...:
Turn the printer OFF, when it is on, by suddenly and sharply unplugging it from the power source.
Also unplug it from the computer!
Leave it that way for 10 minutes.
Plug it back in.
Turn it on if it didn't turn itself on. Wait for it to initialize.
Try the printer again.
It is possible that a sensor switch (of the type that is pushed down or pushed aside when paper is present in the paper path) is jammed or fouled or otherwise indicating incorrectly. A search of the paper path for such a stuck switch (in the position that it would ordinarily occupy only if paper were passing through the paper path) is your last resort in a case like this, before either having the printer serviced, or replaced and recycled (or, if less than a year old, returned to Canon under their standard one-year warranty terms for all the printers they sell. Call 1-800-OK-CANON to start this process).
As for recycling the printer, if you decide to get rid of it: usa.canonwebapp/wcs/stores/
...is the page from which you can order the printer recycled... go to
Printers and All-in-ones, then go to Laser printers, and select the ImageClass D320, then enter your serial number, etc.
Hope this helps.
Posted on Aug 22, 2011
How do I take Canon imageCLASS D320 All-In-One Laser Printer off from "paused" status?
On the printer properties on the computer there will be a paused option (Normally marked as "Pause Printing") in the printer drop down menu on the Printer Queue screen. Click this to remove the tick next to it and it should start printing again.
Feb 20, 2015 | Canon imageCLASS D320 All-In-One Laser...
I fixed a paper jam in my Imageclass D320 printer/copier which involved removing both panels and the ink cartridge to get the paper out. Now it says System Errir E100 and I can't figure out how to fix...
E100 is error for laser unit.
Probably the jam occured because fault on laser unit. To fix error you need to reconnect all connectors of laser unit, or in worst case replace laser unit completly.
Call service...
Hope that helps!
Aug 01, 2011 | Canon imageCLASS D320 Digital Copier
How do you take out a paper jam canon ImageCLASS D320?
First you have to know the position of the paper that has jamed.
the cardinal thing to do is to loosen and open doors that must be opened in order to have a clear view of the paper.
How to open see the marks on the machine. Mainly the paper jams between the drum and the fuser, so make sure you see any green nobs meant for seperating the presssure roller and the upper roller so that the paper is free to move out in case it jamed between the fixing rollers.
See the manual on how to remove paper jams.
Jul 12, 2011 | Canon imageCLASS D320 Digital Copier
I am working with a canon imageclass d320. I believe there is a problem with the fuser and am wondering how i can gain access to the fuser? There is nothing in the manual about the fuser either.
from the left side of machine there are door, when You open them you will have access to fusing unit, but only to the paper exit section.
To dismantle the machine you need to strip all the plastics and much more...
Apr 11, 2011 | Canon imageCLASS D320 Digital Copier
I have a Canon ImageClass D320 copier. It keeps
open the right door and see if any of the sensors are stuck... or out of place... if not then get a can of air and blow out the dust in each sensor...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 15, 2009 | Office Equipment & Supplies
The screen reads paper jam error, but there is no visible paper jam and when turned on a grinding noise occurs
Most likely, there is a paper jam in the fuser unit....which is stalling the fuser rollers, thus causing grinding noise (accordian or fan folded jam)
Oct 24, 2009 | Canon imageCLASS D320 Digital Copier
The install cartridge message won't go away
yes it is problem your copier machanical problem.if it is original cartridge this printer or cartridge problem
Jun 30, 2009 | Canon imageCLASS D320 Digital Copier
Getting LCD Error: Toner not set Insert Toner
Sometimes what causes the problem is the black cartridge guide on the inside rear of the machine. It comes loose and so when you put your cartridge in it does not line up with the contacts properly. The parts cannot be ordered seperately. It comes with the whole rear assembly. The part # for it is HM1-0244
Feb 14, 2009 | Canon imageCLASS D320 Digital Copier
PAPER JAM
laser printers dont use ink.
you will have to check the sensors. first the one where you put the media (paper) then check the registry one (remove the cartridge and you should see it) then the fixing on, from the back it has a small cover you can open an dthen a pair of green coloured levers to remove any jammed paper in fixing (the hot ***'y) then check the delivery sensor right where normally you see the page printed out and coming your way. there should not be any media remains anywhere. also if you copier is dirty it may also be causing this. try to clean it with compressed air.
Oct 29, 2008 | Canon imageCLASS D320 Digital Copier
Imageclass D320 "Install cartidage"
I believe the toner Cartridge has a tab that works a switch when inserted into the machine. sometimes it gets broken.
Aug 03, 2007 | Canon imageCLASS D320 Digital Copier
Canon imageCLASS D320 Digital Copier Logo
298 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
