Question about 3Com NBX 2102 IP Phone
I am getting the following message trying to reset button mappings on a 3C1022 phone. The phone is part of a phone group with unlocked buttons. "unable to save changes.Invalid data has been entered or required data is missing"
Posted by capecod63 on
NBX_Tech
    New Friend:
  • 58 Answers
You need to go to the Telephone group button mappings and click on the lock next to the buttons you want to change. Once you unlock it for the group that the phone is in, you will be able to change it for that phone. Keep in mind that this also allows the other users in that telephone group to change their buttons too.
Posted on Nov 12, 2013
1 Related Answer
Mouline
Manny Quiambao
  • 4 Answers
SOURCE: 3com 2102 IP phone
You cannot program a key with an assigned function like tranfer call or conference call, only with the basic button keys can you program it like Key 0 and Key 1.
Posted on Aug 17, 2007
My garmin nuvi 200 says no detailed maps found
From the Garmin web site:
Question: What should I do if my Garmin nuvi / zumo displays the message "No Detailed Maps That Support Autorouting."?
Answer: Please follow these steps to troubleshoot the error message:
Checking the unit:
  1. Hold your finger down on the screen until the message "No Detailed Maps That Support Autorouting" disappears.
  2. If you get a locked maps message following this error please remove any SD cards in the device and skip down to the instructions for "Getting your unlock codes".If you did not get a locked maps message then please select tools>settings>map>mapinfo button.
  3. Check the box next to the mapping product City Navigator and you should no longer get the "No Detailed Maps That Support Autorouting" message.
Aug 14, 2012 | Garmin Nuvi 200 Automotive Gps Receiver
How to reset map update message on jvc nx7000
Here's the solution from the JVC Customer Service. BE WARNED: this will wipe out all your customizations, including but not limited to favorite addresses and radio station names.
"As for turning off the message about the maps on the radio, please follow the next steps.- Please follow this procedure to perform a factory reset and remove the message.
1. Turn ON the radio
2. Set the Source to "Tuner" mode
3. Simultaneously press and hold the [Disp], [Map] and [Down] buttons for more than 2 seconds
- You must press the buttons in that order
4. When the "Service Menu" Screen appears you may release the buttons
5. Touch the UP/DOWN arrows to highlight "Initialize All"
6. Touch [Enter] to initialize the unit
7. The unit will be initialized and the unit will reset on its own.
Apr 20, 2012 | JVC KW-NX7000 Car DVD Player
Code error for Nokia 6600 "Lockj
UNLOCKING PHONE
Hi you can use codes to unlock the mobile . to get the unlock codes visit this link:http://www.unlocking4free.com/
Here they ask the following details before rendering the unlock codes they are 1. Mobile model 2. Country from where you brought the mobile 3. Provider to which the mobile is locked 4. Imei number of the mobile Finally they will send you the unlock codes at free of cost.once you entered the code in your mobile as for the instruction given by them .your mobile get unlocked and it accepts any network sim to get the IMEI: UnlockPhone Via IMEI. Your phones IMEI is your unique number that is given to eachphone. For each IMEI there is a unique unlock code that once entered into your phone will enable you to use any compatible sim card. You can get theIMEI for your phone by entering*#06# into your keypad. You will only need 1 unlock code to enable you to use any sim card in your phone and enable it to be "network sim free".
you can also try going to this site:http://www.foneszone.co.uk/unlock_codes/ though this site may not guarantee a free service..
or you may try one of this:
reformatting NOKIA Series phone:
simple ways to format your Nokia NSeries cell phones.
(Please do remember that some of the steps below will clean up all your data in phone so remember to make up backup copy of it. Otherwise you will end up loosing them forever.)
Method:1
1. Switch off the phone.
2. Hold down the following three buttons: Green (call answer button, * button, and '3? button.
3. While holding these buttons, press the power button and switch on the phone.
4. When the message 'Formatting' appears on the screen, release all of the buttons.
Method: 2 ( Hard Format)
2. Hold down *#7370# button.
Method: 3 Soft Reset
2. Hold down *#7780# button.
http://techalites.com/2008/05/06/how-to-format-nokia-n72-n73-n81-n95-nseries-phones/
please give time to: ---a score of 4 is highly appreciated----- ---if you think this resolution is helpful kindly click on "YES"---- ---you may also leave testimonial----- ---if I help you please help me---
Thank you for choosing fixya
Roger
Sep 08, 2011 | Nokia 6600
Software are not running in my mob and another thing i want that the unlock code of moto racer game
*#7780# (*#rst0*) - This will soft reset your phone. It is different from *#7370# because all data, like contacts, calendar and notes, are not removed.
It will only reset the phone settings, such as profiles, themes and shortcuts.
The default lock code is 12345.
or try this(But it will fully format your phone)
Method 1: Three Finger Reset for Nokia Phone 1. Switch off your Phone. 2. Hold down the following three keys, Green (call answer button) * (Star) Key, and Number '3' key. 3. While holding The Three buttons, press the power button for switch on the phone. 4. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 2: Hard Format of Nokia Mobile Phone 1. Switch off your Phone 2. Now Press following key-*#7370# 3. Enter Default lock code is 12345. 4. While holding All of the buttons, press the power button for switch on the phone. 5. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 3: Soft Reset of Nokia Mobile Phone 1. Switch off your Nokia phone 2. Now Press following key sequence *#7780# 3. Enter Default lock code is 12345. 4. While holding All of the buttons, press the power button for switch on the phone. 5. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Please Note: The formatting method will erase all of your Phone data. Please take a backup before you Format.
Dec 16, 2010 | Nokia 6600
My backflip is locked and i forgot my blur info , how do I reset/unlock my phone ?
  1. Power off the phone, press and hold camera button ( do not release), press power button until phone turns on.Release power button while holding camera button down.
  2. Release the camera button when prompted (following the Batwings boot screen).
  3. Press the volume down button and wait for 15 seconds for a "triangle !" to appear on the screen. ( message "volume up key pressed " will appear )
  4. With flip closed, tap bottom right corner of darkened display (just above back button).
  5. Select "wipe data / factory reset" on screen
  6. Press "Ok". Wait for "data wipe complete" message to appear
  7. Press "reboot system now"
  8. Press "Ok" . Phone will reboot and complete master reset function
Notes:
Dec 05, 2010 | Motorola Mobility Backflip Smartphone
How to format the nokia n81
2. Hold down the following three buttons: Green (call answer button, * button, and ‘3′ button.
4. When the message ‘Formatting’ appears on the screen, release all of the buttons.
Sep 04, 2010 | Nokia N81 Smartphone
I forgot the unlock code for my Nokia N91-1 phone. IMEI number is 358391000730219. please help! full_bar gave me a master code but it didn't help. thank you!
Soft reset enter this code *#7370#
You can do a hard reset but keep in mind this will reset (erase ) everything.
Hold down the following three buttons: Green (call answer) button, * button, and ‘3′ button
Jun 15, 2010 | Nokia N91 Cellular Phone
My Garmin nuvi says ''maps unavailable''
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The "No Detailed Maps Found That Support Routing" message may appear for the following reasons:
The GPS device is missing it's unlock code
The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select myMaps
  3. Select Manage Maps
  4. Select the device from the drop down menu
  5. The unlock code is located under the "Maps installed on this device" section
    /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Enabling maps on the GPS device:
    1. Touch the wrench icon on the Where to/View map screen
    2. Touch Settings
    3. Touch Map
    4. Touch Map Info
    5. Select the checkbox next to the maps to be enabled on the device
Mar 21, 2009 | Garmin nuvi 260W GPS Receiver
6600
try this if you never change the security code. press"12345" wait 5 min or more before press ok.
If you have change security code you must go to nokia service center or mobile service shop to get security code reset.
Aug 15, 2008 | Nokia 6600
3Com NBX 2102 IP Phone Logo
83 people viewed this question
Top 3Com Computers & Internet Experts
Mike
Vincent G
Vincent G
Sheldon Dedek
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
