Heating & Cooling Logo
Posted on Aug 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The fan is not working - is that a relatively small problem to repair?
Anonymous
Level 3:
  • Comfort Zone Master 43,501 Answers
  • Posted on Aug 22, 2011
Anonymous
Comfort Zone Master
Level 3:
Answers
43501
Questions
0
Helped
10845095
Points
101584
Hi, Replacing is usually very simple.. the hard part is.... finding the correct part...
Here is a tip that wrote about how to buy heating and air conditioning partsonline.
How to find Air Conditioning, Heating and Furnace parts online.
heatman101
I've got a mini one 2002 cooling fan dose not work unless I turn the a/c on if I don't turn the a/c on it will Overheat
7 Common Repair Problems Mini Cooper Owners Face
www.britishamericanauto.com/car.../7-Common-Repair-Problems-Mini-...
Feb 3, 2014 - This describes the top seven Mini Cooper repair problems owners may ... out the cooling fan and other related parts while the vehicle is apart. ... MiniCoopers aren't the most expensive cars to purchase new, and with .... Your article was a great read and at almost 60K miles , I've been through a few of them.
Mini Cooper cooling fan relay switch located Questions ...
www.fixya.com > ... > Cars & Trucks > Mini
Mini Cooper cars & trucks cooling fan relay switch located questions and answers. Ask your Mini cooling fan relay switch located related question. Get free help from topMini experts. ... I've also seen that problem in some Minis that required the fan motor to be replaced. ... The fan on my cooper s 2002 wont go on any idea.
Radiator Fan won't turn off! - North American Motoring
www.northamericanmotoring.com/...problems.../31220-radiator-fan-wo...
Sep 26, 2004 - Join Date: Aug 2002 ... I've posted a few times here on NAM that I never heard my car's electric fan run after the car was shut off. ... If it does not shut off then, replace that relay (you can find this relay at many ... Took the car in today to get thisproblem fixed. ... There is a recall on aux fan for MINI Cooper.
2answers
HOW TO FIND THE CAUSE OF THE BLOWER RUNNING CONTINUOUS
Model of fan? Oscillating? Near heat source , more detail and you may get an answer
NESCO FD-75PR Food Dehydrator quit working. Can I repair it? Company was very unhelpful. Suspect it was heat related? About how much are parts and where do I buy a part?
Does the fan run and just won't heat or is it completely dead. If the fan runs ok then look at the temperature dial. That is the thermostat. It could be bad. Next to check is the heating element itself to see if it isn't open. There's an inline safety device that may have opened too. It looks like a small silver cylinder with one end narrowing to a point. That usually goes first. Try googling Nesco parts to see if any parts are available.
How do I replace the fan on the quadro fx 550 graphics card
fans are relatively straight forward to replace. Assuming you have already bought a replacement correct sized fan. Turn off PC first, remove graphics card, unplug the small white fans power plug from the graphics card. there will be a couple of small screws holding it down, take them out. the fan should just come off. put new fan on by doing the above steps in reverse.
Kitchen Aid Refrigerator (KTRS22QABL01), freezer items frozen on bottom, melting on top of freezer. Refrigerator part works fine
this is an air circulation problelm. If the vents are clear, then check to see if the fan is blowing. If the fan is not working, it is a relatively easy repair to make. a few screws hold on the back panel that will expose the fan and you can get part numbers from the fan directly. Good luck.
I have asuse a8ne mother bord..fan not working
Dear Sir Change the FAN power Cable Related Problem but your have no idea about the cable just send me a fan we are Repair for this Fan Maximum cost 11.54 $ and Normal problem in 8.65 $ charge .......ok.
Email:[email protected]
Web: www.compudesk.in
1helpful
Vw passat air condining not blowing cold air
It's very possible that the fan itself is bad - relatively common on VW's. First check the fuse for the fan on the fuse panel.
You could also have a fan control module problem. Can you hear/feel the compressor turn on? If so, then the module is good and you probably have a bad fan or a blown fuse.
1helpful
Tricity bendix fan oven
The element is almost certainly burnt out .A replacement element is fare cheaper than a new cooker and relatively easy to fit
Apr 07, 2008 • Ovens
3helpful
4answers
Pink pixels across plasma screen.
I have the something going on w/mine!!! Are your fans turning on?Mine are not.I think that's my problem...Get back w/me..thanks,jon.
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
