DateXX DRC-608 Clock Radio Logo
Posted on Aug 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a DATEXX DRC-605 Exactime clock that just changed the date to two days ahead for some reason. How can I change it back to correct date?
Gyula Lacz
Level 3:
  • Master 486 Answers
  • Posted on Aug 22, 2011
Gyula Lacz
Master
Level 3:
Answers
486
Questions
0
Helped
145300
Points
1242
Please follow these steps:
* Press and hold MODE button for 3 seconds: the year digit will flash.
* Press UP ( + ) or DOWN ( - ) to change flashing digits.
* After the first value is set, press MODE button again to confirm and move to the next parameter.
* Continue setting month, date, hour, minutes and temperature display format.
* Press MODE button for the last time to return to the time of day with seconds, after the last parameter is set.
I hope I could help.
Thanks.
gylacz
How can I change the day? My clock is a day ahead. the date is correct
Try backing up (going backwards) with your time until the day is correct, then, add 1 (day's) date to your date (to bring it back to being correct after going backwards).
3helpful
The calendar skipped ahead a day and I can't get it back to where it reads the correct date. Can you help?
Pull the stem out to the time set level. Turn the hand around until the date change. Now push the stem back in, pull to date set level and change to current date. Now the watch is at midnight for that current date. Note you can set to current time of day. The Watch will automatically change to correct date for next day at midnight as it should.
3answers
The day inscription is two days late, monday, watch says saturday
So to change the Day and Date of your Watch, slowly pull the Stem out... (Do note that if you have a Waterproof Watch, you'll need to unscrew the Stem counter-clockwise, which is towards you, until it unlocks, then you can pull the Stem out!) But this is where you need to go slow. If you pull it out slowly you should hear one snap. (It stops on the first notch) If you pull the Stem out all the way, it snaps twice and ends up on the second notch. (See picture below) The second notch, or all the way out, is where the Stem needs to be to set the Time.
day-changed.gif But the first notch, or first snap, is the secret and the key to setting the Day and Date! In the first notch position, you'll see that if you spin the Crown one way, it will change the Day. Spin it in the opposite direction and it changes the Date!
Do keep in mind that you may have to spin the Day and Date a couple rotations because it most likely will alternate between English and Spanish. Just pick the correct Language for you and it's done! When the Day and Date are set, push the Stem in all the way and enjoy your Watch!
If you still have the problem with your Watch changing Dates at Noon instead of Midnight, that just means you're on the wrong 12 hr cycle. (It's set for Twelve at Night instead of Twelve at Noon) All you need to do is pull the Stem all the way out, (second notch) and Spin the Minute and Hour hands ahead 12 hours. If it's Twelve O'Clock, spin it ahead until it's Twelve O'Clock again. Doing that will put the Watch on the correct 12 hour cycle.
Jun 27, 2011 • Watches
1helpful
2answers
My timex watch changes the date at noon instead of midnight. How do I fix this?
This is because you have reversed am with pm.
Set your watch 12 hours back and the problem should be solved.
You might want to wait till midnight or noon to check it's fine.
Note: if you see the day shows the previous day rather than the present day, you have to set the clock 24h ahead.
Problem solved!
4helpful
I have an eco drive and recently in trying to set the clock back to regular time, I must have done something wrong. The time is correct but the date, and day are one day forward. How do I correct this?
the crown of the watch has two clicks, pull it gently once and you can set the date and day, pull it gently again a second time and you can set the time. The proper way to set the time and date is to set first the day,date late at the actual date, then move the hands around the clock until the date change at 12 oclock this is evening, then moving the hands around until you reach the actual time. By doing so you will set the day, date and time in syn to 24 hrs change.
example: you want to change it to sat 12th 11am
set the day and date to fri 11th
then move the hands around clockwise until the day and date change at 12 oclock continue moving the hands until you reach 11am
I'm tryng to set the date without changing the day and time. I've tried to just pull the pin out half way but its not working. How do I do this? My watch has three dials on the face - 1)date, 2) day and 3)...
mcdevito75 here, It takes practice, the crown does have 2 positions, slip a fingernail just under the crown and lift to it"s first position this will allow you to change the DATE (number) once you get the correct Date, push tje crown back in, NOW! pull the crown out to set the DAY itself and the time. On some watches the crowns first position allows both the day and date to be changed by turning the crown in it"s first position clock wise and counter clock wise.
1helpful
I have an automatic watch that shows the day of the week, I can't set it so that it changes from day to day correctly. I've changed it to correct day right after midnight and by the end of the day, it's...
hi,
first you kepp the day and date set yesterday's , for example today is 31st and monday so you set 30th and sunday , now keep rolling time by key till day and date has complitaly changed,remind that do not roll anty clock, it may be damages to your watch,now when you get change day and date its a midnight of 31st and monday, now set the time and get started ,
Indiglo WR 30M
i wind the clock hands forward until the calendar date and week day changes and then i re-wind the hands until it comes to the correct time. when i re-wind the hands, the week day goes back to the correct date and the calendar date does not go back by one day. i don't know if this is the "correct" way to do it, but it works.
14helpful
3answers
Changing the DAY on this analog watch.
Turning it backwards didn't work on my watch. I ended up winding the time ahead several days worth to show the right day of the week (being careful to turn it to the correct 9 o'clock of the day, for me is was the first for morning.) Then I could go ahead and change the date using the first click postition of the stem.
I see that light bulb going off and you whispering "why, of course!"
Dec 03, 2007 • Watches
2helpful
3answers
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Top DateXX Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a DateXX Audio Player and Recorder Expert? Answer questions, earn points and help others
