Question about Canon PIXMA MP495 InkJet Printer
Printer can not print Error Number 5200 - Canon PIXMA MP495 InkJet Printer
Posted by yeonghm2002 on
themreishang pheirei
  • 310 Answers
To solve your problem follow the instruction step by step. Start with printer powered off
1. Open cover of printer and verify that the ink cartridge carriage is not in the center of the printer. Leave cover open.
2. Unplug the electrical cord from the printer and wait 30 seconds.
3. Plug electrical cord back in, when ink cartridge carriage moves to the center of the printer quickly unplug the electrical cord again. This should leave the ink cartridge carriage in the center of the printer so you can get to it.
4. Lift up the gray arm that surrounds the ink cartridges.
5. Remove the entire ink cartridge holder (not just the ink cartridges). It will lift out easily as a unit. Lower the gray arm that you lifted to remove the cartridge holder.
6. Close printer cover. Plug electricity back in.
7. There should be a message about checking the ink cartridge on the display . Thanks
Posted on Aug 22, 2011
  • themreishang pheirei
    themreishang pheirei Aug 22, 2011
    Canon Pixma MP258 Error number P08 will not print from the
    CPU or the Copy Scan (Photostat) and plink only P08 error message on the
    printer panel.
    To Solve the Problem Follow this instruction step by step.
    1. Turn Off
    printer, cable power still plug in.
    2. Press
    Stop/Reset button, don't release the button.
    3. Press Power
    button by holding without release and than release Stop/Reset Button.
    4. Press
    Stop/Reset button two times (2x) now release the Power Button.
    5. Wait until
    service mode to zero (0).
    6. Turn off
    the Printer, cable power still plug in.
    7. Press
    Stop/Reset button, don't release it.
    8. Press Power
    button don't release & than release Stop/Release button.
    9. Press
    Stop/Reset button four times (4x), wait until service mode to "1"
    10. Turn off
    printer, and loose cable power, wait for one (1) minute.
    11. Connect
    cable power, turn on printer again, now this printer ready to use. Thanks
    Canon Pixma MP258 Error number P08 will not print from the CPU or the Copy Scan (Photostat) and plink only P08 error message on the printer panel.
    1. Turn Off printer, cable power still plug in.
    2. Press Stop/Reset button, don't release the button.
    3. Press Power button by holding without release and than release Stop/Reset Button.
    4. Press Stop/Reset button two times (2x) now release the Power Button.
    5. Wait until service mode to zero (0).
    6. Turn off the Printer, cable power still plug in.
    7. Press Stop/Reset button, don't release it.
    8. Press Power button don't release & than release Stop/Release button.
    9. Press Stop/Reset button four times (4x), wait until service mode to "1"
    10. Turn off printer, and loose cable power, wait for one (1) minute.
    11. Connect cable power, turn on printer again, now this printer ready to use. Thanks
Error number 5200 on my canon mx340 printer won't print
find out what is error number 5200 means, then you can figure out what is the problem. Otherwise look up the user manuel or get in touch with canon company to get advice. Most of the time if it is not mechanical problem then may be need to get the driver software delete and reinstall.
Sep 30, 2012 | Office Equipment & Supplies
How to fix Error 5200
Hello and Welcome to FixYa!
Error number 5200 is a
service error. To solve this error follow the given steps:-
First of all unplug the printe
r then open the top and bring the ink cartridge holder to the middle and now raise the gray bar and remove the print head assembly with the cartridges in it. After it lower the gray bar with the head missing and close the top with the head out. Now restore the power and wait till the printer starts.It will tell you to put in the cartridges, Put in the cartridge and restore the print head, close the top and the printer will resume working and Error will be removed.
I hope this solution helps you
For further help, you can take my valuable,professional help by taking my Service
Thank you for using FixYa!
Nov 15, 2011 | Canon MP490 InkJet Printer
Instead of printing error number 5200
Error 5200 and Error P08 are same.. Remove your catridge for few minutes and replace ...
Aug 26, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
My printer Canon PIXMA iP6000D stopped printing and ERROR 5200 appeared.
Error 5200 is print head temperature rise,you need to change the print head.The part number is QY6-0050.If a have been useful please give me a vote :)
Mar 11, 2011 | Canon Pixma iP6000D InkJet Photo Printer
ERROR NUMBER 5200 why when i print a cheet on my
in's in caride.
ucan press resume and hold power and press resume 2x
Jan 25, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Canon ip2700 series error number 5200
when i press for print any word document that time printing processing but after sometimes one message coming that's error 5200. this problem is painful with me .please help me how can solve this problem .please help me immediately.
Oct 05, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Error 5200
Error 5200 is a printhead temperature error, sounds like you need a new printhead. The part number is printed on the side of the printhead. it's a QY6 number
Aug 13, 2009 | Canon Pixma MP480 All-In-One InkJet...
My canon mp830
Error code 5200 means the print head temperature is too high. The only was to resolve this error is either replace the print head or replace the logic board. The print head is available, part number QY6-0061 but you will struggle to find a logic board. The only other thing you can try is resetting the EEPROM on the logic board, this sometimes clears the error. A service manual will show you how to do this: http://www.tradebit.com/filedetail.php/4546483-canon-pixma-mp830-printer-service-manual
Jun 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP495 InkJet Printer Logo
169 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
