HP Wireless Optical Mouse Logo
Question about HP Wireless Optical Mouse
My hp wireless optical mouse stopped working, even with new batteries. please provide a DETAILED step-by-step process for resetting it. i know it involves pressing buttons on the bottom of the mouse and on the receiver, but need the sequence, timing, etc., for pressing them. thanks.
Posted by kathleentsa on
Anonymous
    Novelist:
  • 182 Answers
Namastey!
*clean the bottom of a mouse and if the lens gets dirty wipe it with the soft dampened cloth
* replace the batteries
*Reinstall wireless drivers. If your mouse came with a CD, re-insert it into your computer's disc drive and install all software and drivers.Disable internal transceiver. If your wireless mouse connects to an internal Bluetooth transceiver, disable it using the Bluetooth utility in the Control Panel, and then re-enable it after a few minutes. Then try connecting your wireless mouse.
Posted on Aug 22, 2011
I'm currently using a 2.4 GHz wireless optical mouse product number WR564A. Recently the mouse has stopped working in an odd fashion. The button in the mouse wheel flashes as if the batteries are low,...
its got a battery, replace it?
that small pieces is USB , and uses USB power to work
the mouse has a battery.
page to in your hp manuals states
single AA battery lasts 6months.
http://h10032.www1.hp.com/ctg/Manual/c02542571
1helpful
I have an HP wireless mouse and keyboard, my mouse suddenly stopped working, how can I fix?
It is possible the mouse needs new batteries or needs to be charged.
Try replacing the batteries to see if the mouse starts working.
If that does not work then try re-inserting the wireless receiver into a different USB slot.
Please rate this if you found it useful.
2answers
1helpful
My HP Optical mouse Left Mouse Button has stopped working. The RMB still performs its function (so batteries on mouse still OK etc). I have tried shfitng the USB port etc but nothing seems to fix the...
Similar problem which I resolved today.
I have a hp wireless mouse model no. 5189URF. I bought this in hp online in April 2009. It needs 2 x AA Alkaline batteries.
Steps I did to resolve.
1. Removed battery cover.
2. Removed batteries below which 2 screws exist.
3. Remove 2 screws and remove the top casing of mouse.
4. You can see 2 very small square push button corresponding to left and right clicks in mouse.
5. try to press the left button and make sure its free. The issue seem to be that this button becomes rusty internally and lost contact. Therefore clicks are not recognized. You may need to press it repeatedly and also with a slight thrust circumferentially.
6. You can test your mouse in WIndows Help & support option linked with HP hardware diagnostics tool.
1helpful
My logitech wireless mouse stopped working. I
Turn the mouse over. There is a battery cover that needs to slide to open. Your mouse should take 1 AA alkaline battery. Also there is a recesssed button on the underside that you you can press (with a pen tip or paper clip to reset the mouse). Either the new battery or the reset should solve your problem.
Please rate this solution. Thanks.
1helpful
My Dynex Wireless Optical Mouse just stopped working
If the mouse light is not turning ON even though you have new batteries and the mouse is turned on, then you need to contact the manufacturer for RMA.
Thank you!
New opitcal wireless will NOT work. Batteries
Have to sync it first by resetting the button of the mouse. Then restart the computer.
6helpful
2answers
HP Wireless optical mouse stopped working
You will need to "pair" it with the receiver.  Look on the receiver and you will find a button.  press it then press the button on the mouse.
Then wiggle the mouse around.  You should see the pointer move.
7helpful
6answers
Replace Battery Message
It's a bit iffy, but if you go into the task manager (press ctrl-shift-esc) and look at the list of processes there will be one running called kbd.exe. This is HP's keyboard and mouse driver which, as far as I can tell, does very little but cause a world of pain. If you end the process (select kbd.exe from the list and hit the end process button at the bottom and confirm you want to when prompted) the warning disappears. Nothing else untoward seems to happen.
Jason
HP Wireless Optical Mouse Fading
Ref wireless mouse. Not sure if you have a solution yet but it seems there could be 2 sources to the problem. First a weak or decaying laser. Second, something you have introduced recently that could interfere with the wireless signal eg mobile phone, another wireless device, cordless phone, telephone wires close to receiver or maybe something else. Not sure what you do if the laser is failing other than clean the lens. You might have to get it checked or try a friends mouse to see if it is better. There s also a setting than can change the sensitivity of the mouse. Have you looked at those settings.
Top HP Computers & Internet Experts
Marvin
Marvin
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
