Question about Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver
My dewalt 18v xrp battery wont take a charge - Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver
Posted by Steve Rosenthal on
Repair Ahjoshe
  • Dewalt Master
  • 885 Answers
Depending on how old or more to the point how many times you have already charged the battery, it may be worn out. All rechargeable batteries do reach a point where they won't charge up anymore. If you have fully discharged the battery and tried to fully charge it up again and it won't take a charge or only lasts a few minutes on a charge it may be time to recycle it and buy a new one.
Posted on Jan 30, 2012
5 Related Answers
ddworld
  • 39 Answers
SOURCE: dewalt 18v nicd battery not holding any charge!
Hello
You can revive the dead nicd batteries in your tools.
There is a simple guide that can fix all nicd batteries in few minutes, available here.
Thanks
Posted on Jan 07, 2010
zeniu17
  • 62 Answers
SOURCE: Holding battery charge on 12v DeWalt batteries
Time to replace the batteries. Some batteries will not last very long. My original ni-cads on a Ryobi lasted only 1yr, and the replacement ones are 2yrs old and are still OK. You might be able to check the manufacturing date on your original batteries and that will give you an idea of how long they sat on the shelf before you started using them. Rechargable batteries have limited shelf life.
Posted on Aug 27, 2008
Joe Hogan
  • 10865 Answers
SOURCE: dewalt 18v xrp clutch??
Hello Matt - I recommend that you get your drill to the nearest Dewalt service center. That way you know it will be done right and under warranty. Go to this site to find your closest dewalt service center:
http://www.dewalt.com/us/service/center_finder.asp
Posted on Apr 30, 2009
Anonymous
  • 867 Answers
SOURCE: Dewalt 18v impact drill
if you use it every day, it would be normal for the battery to be at the end of its life. ni cads are usually good for 300 charges/discharges
Posted on Jun 21, 2009
Anonymous
  • 474 Answers
SOURCE: i have a 18 volt xrp dewalt battery that it das
replace bat.try northerntool.com. i bought a couple of after market ones for mine and so far so good
Posted on Nov 15, 2009
Dewalt 18v XRP Problem Powerline
It sounds like you have a defective battery. I would suggest contacting one of our Factory Service Center's to see if your battery is still within warranty. Please see the link provided. You can also give as a call at 1-800-4DEWALT. DEWALT com
Mar 17, 2015 | Dewalt 18v Xrp Battery Dc9096
"Problem Powerline" flash code appears when I try to charge a particular XRP battery in any of my three charges yet all my other batteries charge fine.
Mar 17, 2015 | Dewalt dc9096 xrp battery 18v
Does battry have to cool down before charging?Dewalt DC920KA Heavy Duty Xrp 18V Cordless
Yes, when a battery is being used for a long time, you need to let it cool down and take it to charged. Although there is many fast charger now, but in order to protect the battery, I recommend you to buy a second battery for replace.
And, if you do not know where to find the right one? Here is some suggestion for your Dewalt DC920KA Battery
Jun 17, 2014 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
I bought new batteries for ,my dewalt dw958 drill and when I put the battery in, the drill ran for about 45 seconds then started to smoke and the drill died. The batteries are dewalt 18v xrp batteris
I am thinking the switch or motor is bad, check the switch first. you can locate parts at dewaltservicenet.com. Make a wiring diagram before removing anything, these parts are polarity sensitive.
Oct 28, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Can I use a 18 volt XRP battery in the DeWalt DW938 Reciprocating saw?
Yes. Dewalt says the 18volt XRP battery is compatible with all Dewalt 18volt tools
Have a great day.
Dec 29, 2010 | Dewalt Dw938 18v Reciprocating Saw Sawzall...
Faulty devolt batterie
Try placing the battery in a freezer for six hours before trying to charge the battery and if this doesn't work find a friend with a working charger and make sure using that method that you don't just have a bad charger.
Jul 24, 2010 | Dewalt 12V XRP Battery Pack
Hamer drill xrp
if the battery are less than a yr old should be a warranty
if drill DC920 or DC925 they are on recall for switch. may be co'z the battery to die. have them check at ur nearest service center.
Jul 13, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver Logo
921 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
efs_perpends
efs_perpends
Mike
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
